garmin 72 with oziexplorer
Submitted: Thursday, Jun 14, 2007 at 18:53
ThreadID: 46662 Views:3201 Replies:4 FollowUps:4
how do i program a garmin 72 to connect with oziexplorer to use the moving map. I have it set up ok and every ting works except for the moving map. I think it is something to do with gps settings
Reply By: Member - Bentaxle - Thursday, Jun 14, 2007 at 19:25
peejay
you will need to go into the setup menu and change the interface setting from GARMIN to NMEA before it will work
Mike
May the fleas of a thousand afghan camels infect the crutch of your enemy and may their arms be too short to scratch.
AnswerID: 246842
Follow Up By: peejay - Thursday, Jun 14, 2007 at 20:23
I have tried as you said and it works but i cant transfer imformation between gps and oziex on this setting until i change it back to garmin
FollowupID: 507662
Follow Up By: Bonz (Vic) - Thursday, Jun 14, 2007 at 20:28
u need garmin interface for copying waypoints etc to ozi and NMEA to get moving map working
FollowupID: 507663
Follow Up By: Member - Bentaxle - Thursday, Jun 14, 2007 at 22:45
Peejay, I've got a Garmin Map 76 and all I do is set my GPS to garmin, transfer the information between Ozi and the GPS and then when I want to use the moving map switch the GPS to NMEA. With these earlier GPS's like the 72 and Map76 I've that this is the best if not the only way to do it.
Mike
FollowupID: 507754
Reply By: Member - Phil G (SA) - Thursday, Jun 14, 2007 at 20:01
A few possibilities:
#1 In the GPS "interface" I need to have my Garmin 2+ set to "None to NMEA"
#2 In oziexplorer you need to press "ctrl + S" to start the moving maps.
#3 If you are using a serial to USB converter, then the GPS needs to be turned off when the computer is booted, and you need to enter the correct COM port (often COM5 or 6) into the Oxiexplorer Configuration.
#4 The GPS needs to have a satellite fix for the arrow to appear on the screen.
AnswerID: 246848
Follow Up By: Member - Phil G (SA) - Thursday, Jun 14, 2007 at 21:19
And like Bonz said above, need to change to the "GRMN to GRMN" interface on the GPS to upload waypoints and tracks between GPS and computer.
Theres a way around this, which someone told me about, but I soon forgot it.
FollowupID: 507697
Reply By: Skippy In The GU - Friday, Jun 15, 2007 at 00:11
Have you got the right com port , look in Device Manager and look in Ports.
Not all Serial to USB convertors will work 100%
AnswerID: 246939
Reply By: festy - Friday, Jun 15, 2007 at 12:48
You don't have to use NMEA with Oziexplorer for moving map if you have a Garmin GPSr.
In Ozi's moving map configuration, tick the 'Use Garmin PVT' box and Moving map will read the position from the GRMN protocol output - that way you don't need to switch protocols when you want to upload/download tracks or waypoints.
AnswerID: 247035
