Touch Screen Resolution problem?
Submitted: Sunday, Jun 17, 2007 at 01:13
ThreadID: 46760 Views:2457 Replies:4 FollowUps:6
Hi All,
Anyone have any ideas on this one?? Using 8" touchscreen in conjunction with laptop running oziexplorer maps. Using ponter on touch screen found to be out of calibration with the cursor. Using the 25 point re-calibration check, I got it half right. That is if you split the screen in half, on the left side, the cursor is spot on with the pointer, but on the left side trying to use the pointer to open up on the menu bar the cursor is several centrementres away from the pointer. very frustrating..
I have tried all sorts of ways to get it right but without success.
Would appreciate if someone knows how to overcome this problem.
Thanks, The Nugget.
Reply By: garrycol - Sunday, Jun 17, 2007 at 09:57
I have a 8" touchscreen using oziexplorer on my laptop and I hove no issues - I just use the calibration procedure that comes with the screen and it works perfectly. I do not understand what you mean by splitting the screen in half.
I start my computer with the touchscreen connected and the laptop automatically switches to the touchscreen - I always have dual screen enabled in the display settings in the control panel. If I haven't used it for a while I reset the resolution to 800 x 600 - anything better and items are too small to read on the screen. Once the system is fully run up I open the calibration icon on the desktop - mine only uses a 4 point calibration - touch each of the cross hairs until it beeps and the screen is calibrated.
Mine is always spot on - as I said I am not sure what you mean by split the screen in half as I do not need to do that. Oziexplorer works fine and I can even use my finger to operate the system as well as the pointer.
Garry
AnswerID: 247392
Follow Up By: the nugget - Sunday, Jun 17, 2007 at 10:12
Hi Garry,
Thanks for your prompt reply. When I say the screen is split in half it is not split in the physical sense, but as I move the pointer from the right across to the left the once I pass acroos the centre that's when it gets out of calibration. It is as though the right side is in sync, but as you go across to the left then the cursor gets out of calibration. I think that you have given me a clueas to what is happening and it is to do with the 800x600 and I will follow that up tonight. I'll let you know how I get on.
aapreciate your comments, Cheers, The Nugget.
FollowupID: 508223
Follow Up By: garrycol - Sunday, Jun 17, 2007 at 14:11
I am not sure how your system works but mine has to plug into a usb port for the touchscreen aspect to work - on my computer it has to always be the same usb port as the hardware is installed on that port. If I plug it into another usb port the touchscreen is still there and you can go through the calibration procedure and it beeps etc but the touchscreen does not actually work - no sure this is relevant but it might be related. The screen itself plugs into the external monitor port.
I know understand what you mean by the split screen - on some display resolutions you only get a quarter of the full screen displayed and you have to scroll across or down to get other parts of the screen - when I was first setting mine up I got this and it was a resolution issue - often when both the laptop screen and touchscreen were showing eg not using the dual screen setting.
When I told the computer to use screen 2 (touchscreen as the primary) and on the correct resolution the standard desktop would fit on the screen and I never have any problems after that. Now when I start my lap top if the touchscreen is connected it goes straight to it at 800x600 (the screen will go to 1280x1080 but everything is too small on the screen to read) the laptop screen does not come on. If I start without the touchscreen, the laptop screen comes on at 1280x1080 - the laptop seems to have learn't the two configurations. The only time I have to recalibrate the touchscreen is when the screen has been disconnected for a while.
Good luck with it.
Garry
FollowupID: 508264
Follow Up By: Member - Craig D (SA) - Monday, Jun 18, 2007 at 08:53
Hi Gary, I am having difficulty in getting my Dell lappy to keep the correct res when I shut the lid (defaults to native res). Would it be possible for you to write down an idiots guide to get the correct 800 x 600 res on screen 2 (I am a bit of a dunce when it comes to using dual screens). Thanking you in advance.
Craig D.
FollowupID: 508431
Follow Up By: garrycol - Monday, Jun 18, 2007 at 19:33
Gee Whiz Craig - am not sure I can actually answer your question - I have a toshiba but here goes.
With the computer off - connect the screen and then switch on.
Laptop should open with the laptop screen but detect the other screen - you may or may not have to install the second screen - XP will normally have the drivers but may not.
Then go into control panel and display and active the dual screen desktop. Screen 1 should be the laptop and Screen 2 should be the LCD screen - make screen two the primary screen - select Screen 2 resolution as 800x600 and save. Then select screen 1 and select the resolution you need - such as 1280x 800 and save. Select screen 2 and close the laptop - the LCD screen should still work.
When you start the computer in future - mine recognises if the touchscreen is connected it coes straight to it at the correct resolution. If you start the computer without the touch screen it also recognises this and goes straight to the laptop screen.
I am not sure this helps but it does work on mine.
Garry
FollowupID: 508543
Follow Up By: Member - Craig D (SA) - Tuesday, Jun 19, 2007 at 07:33
Thanks Garry...I was trying it the other way around :( so guess that was my problem!
FollowupID: 508623
Reply By: _gmd_pps - Sunday, Jun 17, 2007 at 19:46
there are different drivers out there ..
one way to confuse them is to change resolution after you have
calibrated the screen .. secondly some drivers have trouble with the
laptop and the xternal screen having different resolutions ..
try to set the resolution the same first, set the driver to recalibrate at
each start (for test) and recalibrate after each start ..
play with it ... I use a 25point calibration and edge compensation
of 130% (makes it a bit easier to reach the very corners..
I do not use a laptop .. have a fix mount mini ITX pc with a 10" screen
but had a similar issue when I was running it off a laptop ... found
it too clumpsy with the cables ... anyway ..
good luck
gmd
AnswerID: 247513
Reply By: allblack55 - Sunday, Jun 17, 2007 at 20:51
The Nugget,
If you have the commonly available 8" screen then just do the 4 pts calibration, that`s all you need as it most likely has a resistive sensor, the 25pts cal. is generally for the capacitive sensor and you will cause yourself unnecessary grief. For anything less than a 10" screen the touch screen is a pain while mobile, we have discarded the touch facility and now use an optical mouse instead of the pointer, we think it`s great.
Leigh.
AnswerID: 247535
Follow Up By: garrycol - Monday, Jun 18, 2007 at 00:09
Hi Nugget - your experience is the same as mine - with hindsight I would have just bought a normal LCD screen - the curser is much easier to use with a cordless optical mouse - safer when driving too - for the dogooders out there it is easier to drive the laptop on the move with the mouse than it is to adjust my car radio or top adjust the A/C - so don't start on the safety aspect - it is safe.
Garry
FollowupID: 508395
Reply By: Ingtar - Monday, Jun 18, 2007 at 11:55
I was working at Coles when they first brought the touchscreens in there. Seemed that every time somebody else calibrated the screens, we would experience the same issues you are describing.
What I learnt was that the calibration process can be an exercise in fine tuning. You need to calibrate, then think about how the cursor moves out of sync with your touch, then factor that into a recalibration. So instead of touching 'on the dot' you touch a little to the left, or to the right, and test the alignment again (or up and down, if that is what is causing you problems).
The reason it does multipoint calibration is to do with different resistances across the screen. So if the left side seems to calibrate correctly, do that as normal and only play with the right hand side.
For note, I also have an 8" touchscreen and once I adjusted it in this manner it holds the calibration quite well.
AnswerID: 247640
