2000 MITSUBISHI PAJERO NM GLX Plus
Submitted: Sunday, Jun 17, 2007 at 20:14
hayden87
hi looking at buying a pajero 2000 model petrol manual just after some help
does anyone knoiw if the have many problems with these if so what are they also how much is it to get the timing belt replaced can it be done at home? and although these can get gas kits on these does anyone know if it is a good idea with the alloy heads or will it bugger them thanks for any help
Reply By: Blaze - Sunday, Jun 17, 2007 at 20:44
2000 Paj's have all the same problems as any make. Don't tow heavy with fifth gear. As for LPG, usually the motor needs hardened valves and seats, but if it has quite a few K's on the motor the valves etc will have already hardened themselves.
Even if the gas does bugger the heads, this will usually take over a 100,000 K's from time of fitting, with the price of replacement of the heads and the fact that you get the LPG subs from Johnnie its still viable
As for the Timing Belt not currently sure of cost in replacing and it depends on your ability as to whether its a home job or not.
247530
Reply By: Member - 120scruiser (NSW) - Sunday, Jun 17, 2007 at 21:00
The only dramas I have had is from lack of servicing. They will sludge up and block the oil pick up if not serviced regularly. They get a minor oil leak at the back of the heads but this is cheap to fix as they are only o rings to replace.
The front diff actuator has a tendancy to break off as its only plastic.
Check the oil level as they can burn oil.
Idle stepper motors are a problem in all Mitsubishi V6 engines.
They are generally a very reliable vehicle.
As for the timing belt, it has the same running gear as the earlier Paj's so it depends if it is a DOHC or a SOHC. Obviously the double overhead cam is more expensive to do. They are complicated but not out of reach of somebody with a bit of knowledge. Alot of workshops don't touch them, I don't know why. I think it is that there is no room for error and a few little tricks to set them up always helps as
well as the special tensioner tool.
If you would like a proper quote, please contact me off line through my website and I will be happy to give you a formal quote.
120scruiser
247537
Reply By: Member - Scoof (SA) - Sunday, Jun 17, 2007 at 22:32
Hi Hayden, I had a 2002 NM petrol Auto,had no prob's at all , great motor but can not comment on the manaul.
Happy Pajero hunting
Cheers Scoof. :-)
247574
