3.0LT patrol(90-92mod)
Submitted: Sunday, Jun 17, 2007 at 21:00
everydoghasitsday
Hi all my son has been looking at a 91mod 3.0ltr(petrol) patrol with 295.000 kms on it the fellow selling it ,my son said has a full service history so it has been
well serviced,just wondering if anyone has driven one and compared it to the 4.2ltr(petrol)4dr wagon,just don't want him to regret it in a few months time when he may have wished he kept looking for the 4.2ltr
any info would be of help and also
fuel wise in any1 knows difference in models
Thanks dave
Reply By: madfisher - Sunday, Jun 17, 2007 at 21:31
Dave I have not owned one, but by all accounts the rb30 is a superb motor that goes forever if serviced correctly and more econominical than the 4.2, but it has to rev to give its best. Make sure you get it checked out by a mechanic
Cheers Pete
247551
Reply By: Bonz (Vic) - Sunday, Jun 17, 2007 at 21:32
The 3.0l is not a bad machine, its a tad underpowered but turbo it and it screams
247552
Reply By: Camoco - Sunday, Jun 17, 2007 at 22:13
Hi Dave,
I have a 3.0 Petrol 1992 GQ with 370,000. Serviced very irregularly. I lift the bonnet just to make sure the engine is still there.
Sure it's a bit underpowered but will do everything asked of it (except hills). It can get a bit frustrating at times but hey, it doesn't drink much
fuel for such a big rig.
It really depends on your requirements and expectations. I don't do much towing other than the trailer and the van at times. But when towing the trailer it's usually got all 750kg in it and runs
well. I push it around town a bit and it responds
well to that treatment. On the highway it's just a lazy cruise. Good for the wallet in both
fuel and points. I have had trips with the BIG boys and other than exhaust note and refueling periods, they never knew I was not the same as theirs.
I have thought about updating the engine but other than a rebuild and turbo, I get a bit put off by the
fuel consumption of the bigger engines and the thought of shelling out more for a diesel engine than what I paid for the rig is too much to bear.
In the end I am happy with my "little" 3.0 ltr and it's great for excuses for being late to something when really I didn't want to hurry anyway.
The little gotcha with the 3.0l is the running gear. Fine if you want to keep it that way but it is not the same as the larger engined models. It uses the navara running gear (
well gearbox anyway). If you want to upgrade to a bigger engine or maybe a chev, you do need to replace the box as
well. The rest is fine as is. Diffs etc will be fine left to handle the raw power of a chev. I am not sure if the gearing is the same otherwise but is still tough enough just the same.
I currently use about 15L/100k around town and about 13L/100 on highway depending on load and hills. Try that with a 4.2. My other car is a Frontera and it is much better all round for power and
fuel but it is injected and more complicated if things go wrong. The ol' 3.0 just doesn't stop and being carby and spark, it would be easy to kick in the guts if it did take a rest. I expect to be still trucking for years yet with no changes.
Cheers Cam
247564
Reply By: Member - steve H (QLD) - Sunday, Jun 17, 2007 at 22:37
Dave
I have a 1990 rb30 and yes it may be a little underpowered but a good exhaust system does make a difference. The best thing i find with it is it runs very smooth and the rb30 doesn't mind being revved high if you need that bit of extra power. As for towing i have never towed anything really heavy mainly my sons motor bike and quad and it handles that really
well. A few people will bag the rb30 but i am more than happy with
mine. I currently get 13 lt per 100 highway (sitting on around 90--100kph) and around 16lt per 100 around town. I am not sure what the 4.2s get but suspect you would be paying more for tha bit extra power.
Go with what you think and enjoy the GQ
Steve
247577
Reply By: Member - joc45 (WA) - Sunday, Jun 17, 2007 at 23:34
Dave,
I believe the motor is a gem (if you could get a turbo'd
fuel injected transplant from a VL commodore would be great) but by all accounts is a very reliable motor. Nissan at the time figured that a carby instead of injection was a plus for working in remote areas.
The gearbox is not the same as the 4.2 petrol or diesel (it's from the ZX30, I bleieve) and has had some issues with 5th, mainly when towing. The transfer case is identical to the larger-engined models. The diffs are also lower-geared than the larger engined models, but consider them just as reliable.
A colleague had some problems with the second throat on the carby not cutting in properly and Nissan went thru about 3or 4 carbys under warranty before they got it right. Prior to that, it had no guts; after being fixed, went like a rocket. Also a warped inlet manifold letting in air later in its life.
They were great value in their day.
Gerry
247588
Reply By: ExplorOz Team - Kerry W (QLD) - Monday, Jun 18, 2007 at 00:08
Hi Guys
There is some great info on the
forum re getting the most out of this great engine.
Being the high performance Nissan Skyline engine it can go exceptionally
well but you need to know what to do to it. (If nothing else keep the revs between 2500+ and 5000rpm and use premium ULP)
Also much lower service costs as they stay in tune.
Do a
forum search on "RB30".
Kerry W
| Kerry W (Qld)
-Helen KellerLifetime Member My Profile My Blog Send Message |
247592
Follow Up By: everydoghasitsday - Monday, Jun 18, 2007 at 17:46
Thanks All
the addvice and differeces gave some good info my son is still um and rrin,it just he thinks its a good buy at 4,000 the 4x4 is dark blue looks good only has one dent on it
well looked after,I guess its better than what i started out with which was a 90mod navara cab/chass 4x4 dont get me wrong the old thing didnt let me down at all it was deisel iam not up there with all the petrol patrols.
Thanks again for the onfo
Dave
508510
