Laptop as a TV ?
Submitted: Monday, Jun 18, 2007 at 22:12
ThreadID: 46842 Views:3706 Replies:7 FollowUps:4
Gday
We are looking into using our laptop as a tv, mainly for the few times we are at caravan parks whilst doing the 'Big Lap'. Does the laptop work out to be a good option or are we better off chuckin in the ol' 30cm tv in the camper trailer if theres room ?
Thanks........
Reply By: brett - Tuesday, Jun 19, 2007 at 00:05
I use an Avermedia PCMCIA TV card in my laptop with no problems, works very well. I've heard of some problems with USB boxes with a separate audio connection, the audio gets ou of sync with the video.
You know have a choice of analogue or digital TV cards, the Avermedia ones seem good.
AnswerID: 247798
Reply By: Redeye - Tuesday, Jun 19, 2007 at 06:09
Have to agree with Brett.
Have one of these and it is great. You will find you may have to use a large external aerial in some sites. But this will be the case with any receiver. The unit only comes with an internal aerial.
Make sure you get the AVerTV Hybrid+FM Cardbus.
Redeye
AnswerID: 247807
Reply By: Gerhardp1 - Tuesday, Jun 19, 2007 at 09:49
Make sure you get a Digital unit. You will have far more channels and clear reception, while analogue sucks almost everywhere.
Don't bother with an old analogue TV - you will finish up buying a set top box en route, and then you may find it won't work with your old TV due to lack of inputs or synch problems, and then you'll have to buy a new TV! This is exactly what happened to quite a few people we met last year.
You will need a decent antenna as well.
AnswerID: 247843
Follow Up By: Redeye - Tuesday, Jun 19, 2007 at 12:24
Hi Gerhardp1
The unit (AVerMedia) I mentioned does cover Analogue, Digital (normal and High definition) ,FM radio as well as analogue input from other equipment.
I was impressed
Redeye
FollowupID: 508663
Reply By: The Birds (WA) - Tuesday, Jun 19, 2007 at 11:35
Gday
Seems like people are happy with Laptop as TV. Our laptop also has a 17" screen so is larger than the ol' 30cm. By using the laptop at least I dont have to cart another item around !!
The Avermedia card sounds pretty good. What antenna set up would be recommended. Not to worried about TV when bush camping as we wont have a generator (only a triple battery system), more for the few times we may be in caravan parks with mains power. At least the TV can occupy the wife and toddler whilst I go fishin !!!
AnswerID: 247859
Follow Up By: Redeye - Tuesday, Jun 19, 2007 at 12:29
Hope this works.
This is one I have.
Site Link
Redeye
FollowupID: 508664
Follow Up By: Mainey (WA) - Wednesday, Jun 20, 2007 at 02:01
do you have psma?? port (is about the size of a 'credit card') or only USB ports ?? as there are new TV tuner cards available for the bigger ports now that you can 'freeze frame' and do all sorts of wonderful things with - even better than a television.
They run about 5 times the speed of usb port tv cards.
FollowupID: 508842
Reply By: Outa Bounds - Tuesday, Jun 19, 2007 at 15:09
I tried a usb type set up with the laptop whilst we were living in Townsville, couldn't get it to work. So my advice would be to do some research and make sure you get the right one (obviously the avermedia one recommended here is probably a good start).
The one I got, can't remember the brand but an Ozzie company sells them out of Canberra. It was digital only and seemed to need extremely strong signal, wouldn't pick up what our pvr would anyway, and that was through the house aerial which was pretty close to new etc.
Also keep in mind that places like Cobar (NSW) still don't have digital TV (we had to sell the pvr after moving here) so once again if you're travelling all over best to go for one that can receive both digital & analogue.
AnswerID: 247886
Reply By: Kumunara (NT) - Tuesday, Jun 19, 2007 at 20:45
The Birds
Use my laptop as a TV with a usb tuner. It has worked well and saves in the amount of gear you have to carry. You can also record to the HDD.
Your old 30 cm TV will add to the weight you are carrying and reduce your available space.
Tjilpi
AnswerID: 247951
Follow Up By: obee - Tuesday, Jun 19, 2007 at 21:21
ditto on the good antenna advice. We have a cheapie usb digital only that is small as but the antenna is also small as. Had to be in a good location to get a signal. After a couple of days in one caravan park I noticed cables running about the place and yes they were antenna plug ins.
I now have a large antenna that used to be analog and digital/uhf but stripped back to the uhf only. Might have to carry it on the roof but I think its the way to go.
Next rule for antennas is get it up as high as you possibly can.
Owen
FollowupID: 508787
Reply By: The Birds (WA) - Thursday, Jun 21, 2007 at 14:58
Thanks for all the replies.
Where can the Avermedia card be purchased in Pert - Any ideas ??
AnswerID: 248263
