Alternator used for welding
Submitted: Monday, Jun 25, 2007 at 14:25
Steve from Top End Explorer Tours
Is it possible to buy a alternator that you can mount to use as a welder?
I was talking to a guy the other day, that remembered years ago there was such a thing, could this also perform as an alternator on a car as
well(100 series) ?
Cheers Steve.
Reply By: GoneTroppo Member (FNQ) - Monday, Jun 25, 2007 at 14:32
You mean one of these
www.mobi-arc.com/faq.htm
248948
Follow Up By: Steve from Top End Explorer Tours - Monday, Jun 25, 2007 at 14:44
what an ingenious device.
Steve.
509873
Follow Up By: Stu050 - Monday, Jun 25, 2007 at 17:20
Or one of these;
www.unipower.com.au/index2.asp
Made in WA
509922
Follow Up By: disco driver - Monday, Jun 25, 2007 at 18:52
There used to be a product called "Auto-Arc which used a re worked alternator to provide welding, 240V and Battery charging facilities.
I note that Unipower looks just it and does the same thing.
Mate had an Auto-Arc on his work
shop Landrover, magic thing to weld with, and enough grunt to run a 9" angle grinder and some lights,240V, at the same time.
No idea on price but if you're going remote it would be worth investigating.
Disco
509946
Reply By: Redback - Monday, Jun 25, 2007 at 15:11
The new generation Ford
Explorers alternater can be used for welding so i was told.
They are apparently over 300watts, maybe even close to 400
248961
Follow Up By: Member - Mike DID - Monday, Jun 25, 2007 at 20:32
The current Pajero Alternator is 1500 watts - 12 volts x 130 amps = 1500 watts.
But it's no use for welding - you need 24 volts to weld.
509990
Follow Up By: Redback - Monday, Jun 25, 2007 at 21:07
OK it's 300 to 400amps then, sorry, still your able to weld with it.
510011
Follow Up By: Axel [ the real one ] - Monday, Jun 25, 2007 at 22:14
Even the one you drowned had the capabillity to supply enough amps for welding , just a little matter of getting it up to 24v , 2x 12v batts and its easy as. , seems to me easier than at home as not as much "setup "variables , just steady welding.
510035
Reply By: CLC50 - Monday, Jun 25, 2007 at 15:25
If you are really in trouble just use Two or three Batteries
see Link
Check out the Link
248964
Follow Up By: CLC50 - Monday, Jun 25, 2007 at 15:26
www.4x4wire.com/isuzu/minutemods/welder/
509891
Follow Up By: Member - lyndon K (SA) - Monday, Jun 25, 2007 at 22:31
Yep, i just use my batts to weld with, you need the hand piece,glass,rods,jumper leads. that all
510038
Reply By: Steve from Top End Explorer Tours - Thursday, Jun 28, 2007 at 06:38
There are some great ideas, thanks.
Cheers Steve.
249596
