Tappet Adjustment 4.2 TDi GU Patrol.
Submitted: Monday, Jun 25, 2007 at 20:49
arjenki
When adjusting the valve clearances on the Patrol 4.2TDi ( Hot .014") what is the most convenient way of turning the engine over by hand to bring the next cylinder to Top Dead Centre ?
Reply By: Martyn (WA) - Monday, Jun 25, 2007 at 20:58
arjenki,
For me I rock the vehicle in second high, with the ignition off of course. Flat as possible and not on a brick path it can be very frustrating. Other than that a socket on the crankshaft nut going in an anti clockwise direction. The latter is more excercise and a little bit of help is usually needed for an acurate valve position. Not sure why you are watching for the next cylinder to TDC, tappets are usually adjusted when valves are at their lowest point,
well that's the way I do it anyway. My opinions etc etc
249093
Follow Up By: Richard Kovac - Monday, Jun 25, 2007 at 21:18
Martyn
Because
When the valves are rocking eg. inlet and outlet that cylinder is at DTC so now you adjust opp. cylinder..
Richard
510018
Follow Up By: Martyn (WA) - Monday, Jun 25, 2007 at 21:30
Sorry I spoke....................
510022
Follow Up By: Richard Kovac - Monday, Jun 25, 2007 at 21:37
No I didn't mean it that whey...
I was only saying what I thought (I think) LOL
NO offence intended
Richard
510025
Follow Up By: Martyn (WA) - Monday, Jun 25, 2007 at 21:50
Richard,
No problem, no offence taken only a
gate. I understood about the TDC method I'm just used to doing the adjustment another way which I find a tad easier, I'm sure there are lots of different ways of doing tappets.
Onward and forward.......................
510027
Follow Up By: Richard Kovac - Tuesday, Jun 26, 2007 at 00:26
gate.
LOl..LOL..LOL..
should have left it as I sed it
Onward and forward....................... no sorry
510062
Reply By: Richard Kovac - Monday, Jun 25, 2007 at 21:20
arjenki
Thy using a socket and bar on the Alt. pully & some pressure on the belts, just take it slow comp. will laek past the rings
Richard
249103
Follow Up By: madcow - Tuesday, Jun 26, 2007 at 07:34
Did
mine like that or put it in 5th in turn the motor over! Easy job to do! 45mins from start to finish. Biggest problem I had was reaching everything
510079
Reply By: Member - Axle - Monday, Jun 25, 2007 at 21:48
Adjust them while its idling!!, most mechanics from old school did it all the time.
Watch out for the oil though...Lol
Cheers Axle.
249112
Follow Up By: Martyn (WA) - Monday, Jun 25, 2007 at 21:57
Axle,
Your right about the oil mess, plus if you have a tight tappet it chews the feeler blade to bits and sucks the feeler blade bits into the engine. The old engines you used to be able to do this successfully one were the old Ford and some Vauxhall engines, the Ford Kent engine if I remember correctly.
Any tappets that have to be adjusted with a screw driver and a spanner would be very difficult this way, virtually impossible I would venture to say. Your right Axel takes me back a few years this response, close on thirty, you've got a good memory.
510029
Reply By: Member - joc45 (WA) - Monday, Jun 25, 2007 at 22:45
I jack up a back wheel, put it in 5th, and get someone to watch for the TDC mark as I turn the wheel in a forward direction. Seems to go around ok despite the lsd, tho it does need some leaning on to get it moving against the compression. If you go past it, go around again, rather than backwards.
You'll need a mirror and a light to spot the TDC marker on the gear cover, as it's pretty hard to see otherwise. A bit of zinc cream smeared on the relevant markers also helps.
Gerry
249128
