loading raster maps (memory jog)
Submitted: Tuesday, Jun 26, 2007 at 20:32
Gob & Denny
evening all
with having swapped laptops i am now reloading the necessary bits and pieces and i cant remember the easy way to load my raster maps and desert series into Oziexplorer can somebody please jog my memory or belt me over the ears with alump of 4x2 some method has to work
steve
Reply By: Member - Phil G (SA) - Tuesday, Jun 26, 2007 at 22:07
Depends a little on which version. But no matter what, you'll need to go to the oziexplorer website, australian page to get the calibration files for the raster maps.
http://www.oziexplorer.com/
249363
Reply By: Member - Jiarna (NT) - Tuesday, Jun 26, 2007 at 23:33
In Ozi, go to File - Import Map - ECW Maps then browse to where the raster map files are (CD, DVD, or HDD)
249371
Follow Up By: The Explorer - Wednesday, Jun 27, 2007 at 18:58
Hello - yes this will work and calibration will be correct but keep in mind corner markers will not be in correct position. The maps in question have white borders and OziExplorer will think these areas are part of the actual map…unless corner markers are moved to actual map corners. Doesn’t make much difference when sitting inside using OE but it is important to have corner markers in correct position when using Moving Map so that adjoining maps are loaded as you move on to them.
The calibration (*.map) files available for download (as suggested by Glen) are therefore the best option as the corner markers have been positioned in correct location by some kind hearted soul. Just make sure you download the right ones for the series of maps you have.
510487
Follow Up By: The Explorer - Wednesday, Jun 27, 2007 at 19:00
Sorry meant PhilG - not Glen
510488
Follow Up By: Member - Jiarna (NT) - Wednesday, Jun 27, 2007 at 19:07
Hi Greg
Thanks for that. I use the 250K Mosaic which has no edges (not on land anyway!) so wasn't aware of the potential problem.
510494
Follow Up By: The Explorer - Wednesday, Jun 27, 2007 at 19:13
Yes - so do I - much easier than separate maps. Corner marker issues and getting right calibration files are a common solution to many problems reported on forums relating to natmap/oziexplorer so spread the word.
510501
