ARB Bull bar - Lightforce lights
Submitted: Tuesday, Jun 26, 2007 at 21:43
Outnabout David (SA)
Just wondering about fitting Lightforce 240 XGT's to an ARB winch bar on an 80 Series cruiser. I realise they won't fit to the original spot brackets and don't mind having to fabricate new mounts. It is more of a case of whether they would protrude too far.
I know Blitzes will fit but like the look of the XGT'S better.
I just don't want to get it wrong if I chose the wrong lights again.
Reply By: long haired nomad - Tuesday, Jun 26, 2007 at 23:49
I have a hilux and had to modify the top centre cross bar to fit hella 4000's. They dont protrude at all. Ive been down too many tracks and had to do a u turn for one reason or another and most times i had to push over sum trees and shrubs to do a 3 point turn. If the spotties protruded i would have either broken something or moved the lights.
249373
Reply By: lc_120man - Wednesday, Jun 27, 2007 at 00:30
David,
XGT's should fit...You just have to drill new holes for them
I got them fited with the ARB sahara bullbar on the Prado.
Here is the link on how to mount them on 90 series (This is for blitz I think)....
Site Link
Stan
249378
Follow Up By: Drew - Karratha - Wednesday, Jun 27, 2007 at 13:52
Blitz fit XGT's dont...
510402
Reply By: Member - Sam (NSW) - Wednesday, Jun 27, 2007 at 08:03
You can also take the base mounts off the lights and reverse them. I did this to mount
mine on the Nissan factory steel bar on the GU. Didn't have to drill any extra holes or anything. Fit perfectly with room to spare.
249393
Reply By: Member - Michael J (SA) - Wednesday, Jun 27, 2007 at 14:05
David, I have XGT's fitted on an ARB winch bar on the Troopy.
They bolt straight on, do protrude out a tad -75mm or so- but looking at your profile not much more than the IPF lights you have at the moment...XGT's are a bit higher tho'.
One thing I have found out, I have to move the light to one side in order to
use a high-lift jack on the bull bar mounts...bummer
Michael
249454
