GU 4.2 oil leak at sensor.
Submitted: Monday, Jul 02, 2007 at 09:37
Austravel
I've got an oil leak in the front of a GU, towards the top of the engine where a set of wires run to what I believe might be a sensor. I recall sometime ago reading about oil leaks from the speedo sensor being common. Is this the case? Any ideas on a fix, this is the second time it's happened, first time under warranty?
Reply By: Member - joc45 (WA) - Monday, Jul 02, 2007 at 12:15
sounds like the tacho sensor, mounted high on the timing cover, just below the
water outlet, with a pair of wires which come out. It's a relatively solid block, and I doubt if oil would seep thru it. I suspect that a new gasket and sealant will probably fix it.
I've owned a GQ and a GU and never had problems with the sensor.
Gerry
250288
Follow Up By: Austravel - Monday, Jul 02, 2007 at 14:21
Thanks Gerry,
That'll be the one. Wasn't sure how it sealed, if it's just a gasket it'll be easy to replace.
Thanks again.
511459
