75 Series Ute
Submitted: Tuesday, Jul 03, 2007 at 12:46
Member - Howard T (QLD)
My son owns a 75 Series Ute thats using quite a bit of oil. Drove 500 k on the weekend and used approx 5 ltrs. Not being mechanically minded I will have to get the job done by a mechanic. Anyone got any ideas how much a rebuild would set him back. I would assume thats whats required.
Thanks in advance for you help.
Howard.
Reply By: Member - John L G - Tuesday, Jul 03, 2007 at 13:48
If its a 1hz motor it would be best to simply replace.
You can buy new out of the toyota box, genuine factory for between $8-10K if you look around.
250491
Reply By: ross - Tuesday, Jul 03, 2007 at 17:33
They came with 4 engines so you need to tell us which one.
I had my 1HZ rebuilt 2 years ago and it cost me $5k for a long 1HZ motor. I had to remove the engine and strip it of all the outside parts,sensors and plugs and replace them.
You could add another $2k+ if you have to pay someone from start to finish.
If you have to pay someone to do everything,its best to have all the reconditioning and installation done by the same
shop.
There is also a list of small items like
water pumps,oil,filters,coolant,hoses,timing belt and a few large items like radiator,clutch
fuel pump and injectors to think about.
The manifolds and flywheel also may need machining.
You can leave some of these items out but if you have to go back and do them in 6 months with the engine in,it will cost much more.
250533
Follow Up By: Member - Howard T (QLD) - Wednesday, Jul 04, 2007 at 14:34
Ross
Its a 1HZ motor. Seems to me that the repairs may cost more that the vehicle is worth.
Thanks for your replies.
Howard.
511847
Follow Up By: Member - Davoe (Nullagine) - Wednesday, Jul 04, 2007 at 17:04
Price up a second handy fitted and flog it off or flog it off for parts
you can spend far to much mucking about with dog f4bys - trust me I should Know!
511866
