Terrano & caravan
Submitted: Thursday, Jul 05, 2007 at 19:06
ThreadID: 47429 Views:3397 Replies:4 FollowUps:2
We are looking at purchasing a caravan - we have a Nissan Terrano 2.7 diesel - manual - is there anyone out there with this vehicle towing a van - who can advise us on the ball weight etc -
thanks - jules
Reply By: Shaker - Thursday, Jul 05, 2007 at 19:10
What size & weight caravan?
AnswerID: 250938
Follow Up By: disco driver - Thursday, Jul 05, 2007 at 19:29
Hi Shaker,
The way I read the post is "that is actually what they are asking", in a round about sort of way.
What size and weight caravan would a Terrano capably tow?
Depends on towbar rating and vehicle limits.
IMHO nothing bigger than 15ft, preferably poptop, and not too heavy (up to 1.0 tonne empty). Might rule out some of the OFFroads on weight.
Basically, personal preferences and proposed use will dictate choices.
Not much help, I know, but there are so many variables to consider.
Disco
FollowupID: 512081
Follow Up By: Shaker - Thursday, Jul 05, 2007 at 19:55
They are an extraordinarily capable tow vehicle.
You are right, I didn't read the post correctly.
FollowupID: 512085
Reply By: redmeatgrr - Friday, Jul 06, 2007 at 00:05
The Terrano Ii should tow 2.800 kg legally, but some brochures by Nissan indicate a max. tow limit of 2.000kg, which is not the case. The Overlander mag also shows max tow limit of 2800 kg in their test. This is also evident from the the figures on the firewall. The max towball weight as determined by Hayman Reese in 2002 for one of their towbar models is 250 kg but this is inconsistent with the genuine Nissan original towbar figure which was 100 kgs but this Nissan towbar was also only rated at 2000 kgs.
I've towed around 2000kgs with the Terrano II and it goes beautifully. You must also remember that these Terranos were and are just about the toughest tow hacks in Europe where the big Landruisers and Patrols are less common, particularly in the UK, and many websites etc. show these cars towing big horse floats over there because there's not much bigger anyway.
AnswerID: 251001
Reply By: Member - Bucky (VIC) - Friday, Jul 06, 2007 at 07:54
Julie
10% total weight on the tow ball.
Does not matter if loaded or empty. So you may need a couple of trips to a weigh bridge to get it sorted.
Also check to see if there is a heavy duty towpack on your vehicle. The towbar should be stamped, mine is done on the main bar running between the chassis rails, and rated at 250 kg.
Friends of ours are travelling Oz, in their Terrano with a Pratliner Van and just love it. I helped them with a few of the tedious choors to get the weights right, and setting up their power ect
Bucky
AnswerID: 251016
Reply By: Member - Julie P (VIC) - Saturday, Jul 07, 2007 at 09:29
Thanks for the input - we love our Terrano and have towed our cmaper trailer for the llast 7 years with it very happily and easily. But as we get older - we are finding that maybe we need to get a bit more comfort - our trailer is basic - no built in kitchen etc - need to go outside to make breaky, when somemornings it would be lovely to be able to make it inside and stay in bed - especially when it is raining and cold, as we had on our recent trip to outback Qld - 36 hours straight with no let up around Hughenden - and more elsewhere -.
Anyway - you have given us info to work with, and a good starting point.
Knew we could rely on this forum.
jules
AnswerID: 251165
