water taste
Submitted: Wednesday, Jul 11, 2007 at 16:39
karynjack
We have a new Paramount van I have tried two types of hoses one a flat type the other a blue reinforced type but the
water has a plastic taste.
Has any one had this problem ? and if so how can I fix it.
I enjoy this page Fred.
Reply By: Gerhardp1 - Wednesday, Jul 11, 2007 at 16:40
You need to use food grade hose, not garden grade.
251902
Follow Up By: Notso - Wednesday, Jul 11, 2007 at 16:44
If it's a new van you can get some taste from the
tank also.
So if you are using food grade hose try filling your
water tank about half full then dissolve about a kilo of Bi Carb soda in a watering can of
water. Pour this into the
tank and then fill it up the rest of the way.
leave it soak for a couple of days then drain and rinse the
tank a couple of times.
Might help
512966
Follow Up By: Gerhardp1 - Wednesday, Jul 11, 2007 at 16:47
True, hopefully they use food grade hose for all the internal plumbing.
512967
Follow Up By: Notso - Wednesday, Jul 11, 2007 at 18:23
Yep, I had to replumb some of my pipes at they had used black wrinkly pipe for
water fill lines. The stuff you use for waste
water pipes. Never know what they are up to till you get the van home and have time for a really good look.
512981
Reply By: Member - Phil G (SA) - Wednesday, Jul 11, 2007 at 18:13
I had some problems with the blue "water" hoses. It cut a long story short, the Hardy Pope brand blue
water hose gave a plastic taste (its the shiny light blue hose). The Nylex brand braided, stiff, light blue hose leaves no taste whatsoever. I replaced every hose including filler and breather with the Nylex hose, and never have a problem with
water taste.
251921
Reply By: Keenycruiser - Wednesday, Jul 11, 2007 at 18:38
Attach a filter to the hose or fit one inside the van under the sink and have a separate tap just for filtered
water. Not only will it take the taste of plastic away but also the taste of
bore water or some river
water in bush towns. As the van is new you will appreciate the soft tasteless
water for years to come.
251936
Reply By: mattie - Wednesday, Jul 11, 2007 at 20:27
we have kk and the
water had a taste if the
water sat in the hose for a couple of days more when u used the manual tap at the front, the taste goes away after a period of time if u use it a little more often it won't take as long.
MATTIE
251958
Reply By: Member - Debbie R (SA) - Wednesday, Jul 11, 2007 at 21:30
Hi.
You will get this taste for a while regardless, the best thing to do is use bi-carb as already suggested, and follow up by adding a filter and you should be fine. s I am sure you already know it takes a while for this taste to leave new plastic, its the nature of the beast.
Good luck
Barry and Debbie.
251972
Reply By: karynjack - Wednesday, Jul 11, 2007 at 22:02
We would like to thank all those who responded to our question on plastic taste in our
water.
Thanks again.
251977
Reply By: MEMBER - Darian (SA) - Thursday, Jul 12, 2007 at 08:58
My 6m light blue (with white fibre reinforcing) filling hose is fine (off the roll at Bunnings I think). The short hoses in the camper used for plumbing seem to be made of the same sort of pipe. Never had a taste in out
tank - we always keep it full of tap
water when not in use (no air) - replaced with rain
water, just before we go on a trip. I bit of follow up fitting of quality short hoses by yourself will probably do the trick - the maker of the actual
tank would be sure to class their
tank as odourless ! If the hoses are the culprit, it would be sad though - usually caused by the van manufacturer never using their own product - probably never go caravanning - might know bugger all about it, even !
252028
