Thursday, May 15, 2003 at 12:46
Solar King,
Let us talk of some FACTS another word would be TRUTH or HONESTY.
I have read the Fridge Test done on nine ( 9 ) different model fridge's, the tests were carried out inderpendently and not in the premises of, in the presence of, or under the influence of any of the partisipating manufacturers by "Australian 4X4" magazine, to deny these results talk with them, not me as I am only restating the FACTS they printed.
I have the report in front of me, stated FACTS from that test are as follows....
Starting in a controlled temperature hot room at (plus) +35 degree, in a 3 hour test.
# LIEMACK, was the only fridge to go BELOW -15 degree, it went down to (Minus) -21.4 degree, with an average Amp/Hr of only ... 3.8 Amps, the fridge then cycled on & off 3 or more times.....
# Trailblazer, went down to (minus) -10.1 degree and the average Amp/Hr was .. 5.8 Amps, the fridge then cycled on & off 3 or more times, indicating that it could not get below this temperature....
# LIEMACK, dropped from +35 to Zero degree in only .. 28 minuites.
# Trailblazer, dropped from +35 to zero degree in .. 42 minuites.
# LIEMACK, dropped from +35 down to (minus) -15 degree in only 55 minuites, no other fridge reached this temperature with-in 3 hours.
# Engel 39 Lt, dropped from +35 down to (minus) -5 degree in one (1) hour and 22 minuites, in 3 hours it only went to -9.5 with an average Amp/Hr of 4 Amps.
As for your stupid statement of weight, have you ever picked up a Liemack fridge, I think not, are you aware that they have sturdy metal handles each side to use to pick up and also use as tie down points.
Do you pick up your fridge when it is full of food, that is heavy, or do you first have to remove the food from your fridge before you pick it up...?
Let us stay with the TRUTH and keep this
forum Honest, as for
battery power used the test also answers that for you.
Hope you are not too embarrised by the on record published Facts, as it was you who did first mention the above test report.
12840
