Chain sharpeners
Submitted: Friday, Jul 13, 2007 at 08:33
ThreadID: 47666 Views:5728 Replies:14 FollowUps:3
Hi all.
I am looking at purchasing some sort of chain sharpener and wanted to hear your opinions and experiences. I only use my chainsaw occasionally but still would like the option of being able to not need to go to a shop to get it done, particularly if I'm in the bush.
Walter
Reply By: Mike Harding - Friday, Jul 13, 2007 at 08:37
A file? Works for me.
AnswerID: 252158
Follow Up By: Robin Miller - Friday, Jul 13, 2007 at 08:53
Totally endorse use of file only as well.
I probably sharpened mine once a day and it only takes a couple of minutes unless you really let it go bad.
You can get a special little file holder that has marks on it to asist holding file correctly also at chain saw shops.
When first got chains saws I go one of those little electric ones , used it once and it really doesn't do the job of the much cheaper file and holder.
P.S. by a few files , they are cheap. but don't keep edge to long.
Robin Miller
FollowupID: 513235
Follow Up By: Member - andrew B (Kununurra) - Friday, Jul 13, 2007 at 09:23
I'll back the file as well. I used to use just a file, and then about every 5th sharpen, would get out a guide similar to what Robin has mentioned. The guide took a lot longer than by eye or feel, but got the correct angles etc back on track after a few eye/feel sharpens
Cheers Andrew
FollowupID: 513242
Reply By: KSV- Friday, Jul 13, 2007 at 09:10
Agreed. Have tried stone bit for drill as well as some other fancy drill bit. All rubbish and file is the best. Get a bit of time to use it, but once mastered it does not take too long to sharpen chain. Just make sure that it is special file and it has proper diameter suitable for your chain. Bunnings stock them.
AnswerID: 252162
Follow Up By: disco driver - Friday, Jul 13, 2007 at 11:10
And............. Bunnings will know the correct diameter file for your saw chain.
I THINK NOT.
Disco
FollowupID: 513259
Reply By: AdrianLR (VIC) - Friday, Jul 13, 2007 at 11:17
Another vote for a file. You can do more damage much more quickly with an electric sharpener than with a file. I do touch ups with a file then every so often get a service place to sharpen it to get the angles back to where they should be. I have an electric version as well but no long use it. The grinding stones wear very quickly (therefore giving an incorrect bevel) and if you press too hard they break.
Adrian
AnswerID: 252183
Reply By: Mainey (WA) - Friday, Jul 13, 2007 at 12:08
ALL AGREE... yes a hand file
Got to a chainsaw shop that sells YOUR brand of chainsaw and ask them what SIZE file you need. Get at least two files of different brands, I use plastic handle as wood handle tends to turn and split. You can then go to Bun-nings and get the same size in various brands to see what type of handle you prefer to use, but you need the exact diameter file first.
I sharpen my chain at least a few, maybe 5 or 6 times a day... I use it to cut fire wood x trailer loads.
Don't let the chain get dull, it gets hot, causing bar wear and creates unwanted pressure on bearings and components as well as taking longer to cut the logs.
Every time I refuel or replenish the chain oil I run the file over the chain, it only takes a few minutes and saves time and money in saw repairs and you get to have a much deserved rest as well.
AnswerID: 252187
Reply By: pmacks - Friday, Jul 13, 2007 at 12:18
G'Day
i use my chain saw a lot, almost every weekend and i use a twelve volt hand grinder that i bought from stihl years ago clips directly to the battery terminals of the car and works a treat, it also has the guide marks on the tool and takes about 1 minute to sharpen the chain, bugger fiddling around with a 3/16 file
Pmacks
AnswerID: 252188
Reply By: Hairy - Friday, Jul 13, 2007 at 12:42
Gday,
husqvarna make a good set. It includes files, handle and a really good guide.
www.husqvarna.com.au/ ( File kit )
AnswerID: 252197
Reply By: Pajman Pete (SA) - Friday, Jul 13, 2007 at 13:12
Ditto the Stihl sharpener. I used to use my saw in my business and used both a file and the electric sharpener.
I still have both and tend to take the file with me for the day, together with several spare chains. When I get back to the shed I put the saw with the bar in the vice and use the electric sharpener to redress the teeth and reset the height guides.
Pete
AnswerID: 252206
Reply By: meandet - Friday, Jul 13, 2007 at 15:35
Hi Walter
Lash out and buy yourself a jig that clamps to the bar with full adjustments for angles and depth. I have used one for many many years and get perfect results every time. They are (or at least were when I bought mine) called "file n joint". Blunt chain saws are hard work.
AnswerID: 252223
Reply By: Mr Fawlty - Friday, Jul 13, 2007 at 16:23
Oh Yet again I'm the lone dissenter.....I bought a guide that fits my 12vdc "rotary tool" (fake dremel), it does not use a grinding wheel in the conventional sense but uses a diamond impregnated burr. Cuts cleanly and outlasts the carborundum wheels and gives a superior edge which is what you want because a dull edge causes extra frictional losses. Can be used on the saw or used in a sharpening jig in a vise. Can be got in various diameters to suit different teeth.
I fully endorse and reccomend it & would never bother with a file again unless forced to.
AnswerID: 252233
Reply By: vuduguru - Friday, Jul 13, 2007 at 21:28
file!
AnswerID: 252278
Reply By: fishaholic - Saturday, Jul 14, 2007 at 08:17
get a file and a bar holder for the file, electric ones will stuff your chain up. Dont listen to people who own the electric ones, it takes a little longer with a hand file but will be sharper and the chain will last 10 times longer. The electric ones get each blade too hot. Also you probably knew this but always sharpen your chain every fuel tank. Also change your bar around every now and then, then it wear the same.
Crawf
AnswerID: 252305
Reply By: Member - 120scruiser (NSW) - Saturday, Jul 14, 2007 at 10:39
Firstly you need to know what size chain yours is, 1/4, 3.25 or 3/8.
Generally 1/4 chains are on small saws, 3.25 on medium and 3/8 on larger saws. For example in the stihl brand 009 has 1/4, 028 has 3.25 and 034< have 3/8. The really big saws can have 4.04 but not many of these around in the private market.
See the table below for file sizes.
Its also good to use a bench grinder to get the size of the cutter even on both sides so the saw doesn't cut on an angle.
1/4 chain 5/32 (4mm) file
.325 chain 5/32-3/16 (4.5mm) file
3/8LP chain 3/16 (4.7mm) file
3/8 standard chain 13/64 to 7/32 (5.5mm) file
.404 chain 7/32 to 1/4 (5.5 to 6mm) file
If you aren't sure of your chain size take the chain into your local mower/chain saw shop and say you want a file and guide for this chain.
Hope this helps
120scruiser
AnswerID: 252318
Reply By: Harry - Saturday, Jul 14, 2007 at 17:49
Ditto Hairy about the Husqvarna sharpening jig. It has rollers and fits snugly on the chain so your angle is set. All you need with it is the right size files (don't forget your rakers) and probably a clamp that drives into a log to hold your bar whilst sharpening.
Check it out.
Ave a great day
AnswerID: 252377
Reply By: Member - Bucky (VIC) - Sunday, Jul 15, 2007 at 08:14
File with a guide ,,,, never go wrong ,,, just a few minutes and you are up and running, with a super sharp chain.
Problem is with rotary sharpeners they can butn going in and if you are lucky enuf to sharpen the chain you can burn the chain coming out, if not burn it you can dull off your good work ,,,, Too much hit & miss
Bucky
AnswerID: 252471
