Towing mirrors for 2007 ST-L Patrol
Submitted: Friday, Jul 13, 2007 at 14:46
ThreadID: 47675 Views:2430 Replies:5 FollowUps:3
I need to buy a set of towing mirrors for my 2007 ST-L Patrol. Appreciate any suggestions as to the best type to use. I am concerned the strap on type will slam back on the door at speed.
Reply By: dave_c - Friday, Jul 13, 2007 at 17:29
i have COPPA ROSSA towing mirrors. so far so good. they do not move. plastic strap around car mirror with slide adjustment and a metal arm with suction cup on to door. very stable setup. do a search as i dont know their web address.
cheers dave
AnswerID: 252243
Reply By: Max - Sydney - Friday, Jul 13, 2007 at 18:08
I use the Coppa Rossa ones too. I have had to learn to take up all the slack when I put them on the mirrors, and keep all the adjustments tight, as they get quite a bash when you pass a truck that does not have wind deflectors and with a head wind in particular.
One trick - when you put the mirrors on, have a wet tissue handy to wet the suction cup and door to give a good seal there.
Practice helps
Max
AnswerID: 252251
Reply By: Member - barry F (NSW) - Friday, Jul 13, 2007 at 18:43
We have Aussie truck mirrors, available from most caravan retail shops, quality
automotive paces like Auto pro, repco & ISP etc. Not cheap, if memory serves me correctly about $100 for the pair. They are fully adjustable, stable, removeable, & do not damage tinted windows or your duco. Best wishes
AnswerID: 252257
Follow Up By: awill4x4 - Friday, Jul 13, 2007 at 20:32
More like $100 each Barry, but I'm with you, Aussie Truck Mirrors for me to. A great range in the adjustments easy to fit and don't move a millimetre when set up correctly.
Regards Andrew.
FollowupID: 513351
Reply By: Member - shane (SA) - Friday, Jul 13, 2007 at 22:02
seen them today, $125.00 a pair, at dave bensons.
shane.
AnswerID: 252283
Follow Up By: Montereykeys - Saturday, Jul 14, 2007 at 17:59
Thanks for all the replies. Do the Aussie truck mirrors take long to attach and remove?
FollowupID: 513435
Reply By: Member - R Send - Saturday, Jul 14, 2007 at 19:33
Check out eBay for the Aussie Truck Mirrors - I think you will find them at $80 each plus postage.
AnswerID: 252397
Follow Up By: Member - barry F (NSW) - Sunday, Jul 15, 2007 at 09:50
No they don't take long to put on or remove. It will take you a little longer the first time you put them on, but after you have them set up its all easy from there.
They have a ratchet tensioner which you are able to release allowing the strap enough slack to take them off. You just have to tighten up the ratchet when putting back on & you are in business & the mirrors are usuly still in focus.
One important point, we find you need to have the windows up in order to keep them from vibrating about, so if you dont have air con it might be a problem.
FollowupID: 513534
