A Good Idea - Show and tell - Keeping the wind and rain out
Submitted: Tuesday, Jul 24, 2007 at 21:02
Derek from Affordable Batteries & Radiators
We enjoy the
bright light that our pop top van offers but if it is cold or raining then you need to close the top windows.
I decided to buy some 1mm clear polycarbonate from Bunnings to make some weather shields.
They work great and also help with the air conditioning in summer.
These are cut just slightly bigger than the zipper so they can be easily removed and are held in place by the zipper when in position.
We wrap them in a towel to stop scratching when traveling.
Derek.
Reply By: Richard Kovac - Wednesday, Jul 25, 2007 at 00:14
Thats a good idea Derek
will have too have a look into it, you realy only need two of them
hay for the weather sides
Richard
254337
Follow Up By: Derek from Affordable Batteries & Radiators - Wednesday, Jul 25, 2007 at 06:43
I made 4 up.
My van has 6 openings and I thought that 4 would be enough. Also I managed to cut the 4 out of 2m of material with almost no waste.
Derek.
515389
Reply By: Member - Patrick (QLD) - Wednesday, Jul 25, 2007 at 03:42
Great idea Derek.
Did you use the flyscreen as a template to create the exact shape and what did you cut the material with?
Cheers, Patrick
254344
Follow Up By: Derek from Affordable Batteries & Radiators - Wednesday, Jul 25, 2007 at 06:40
The 1mm polycarbonate cuts with a normal large scissors. It is supplied with clear protective film on both sides. Simply hold a piece over the opening from inside and because you can see the zipper mark it with a marker 10mm bigger than the zipper and then cut to shape.
Whole job took about 10 mins. A lot quicker than the queue at Bunnings.
Derek.
515388
Reply By: Moose - Wednesday, Jul 25, 2007 at 13:30
G'day Derek
Looks like a damn fine idea but I must be thick because I can't see how they stay in place :-) Could you elaborate? Do you slip them in between the material bit of the zipper and the van canvas? Why don't they just flop down - I wouldn't have thought 1mm to be thick enough for the required rigidity?
Thanks from the Moose.
254390
Follow Up By: Derek from Affordable Batteries & Radiators - Wednesday, Jul 25, 2007 at 13:47
Yes, they fit between the flyscreen and the zipper. You cut them only slightly bigger then the opening.
1mm polycarbonate is very rigid. (Similar to a credit card)
515446
Follow Up By: Moose - Wednesday, Jul 25, 2007 at 13:50
Thanks Derek - the polycarbonate bit didn't register - I was thinking of that thick plastic sheeting. Now I know what you mean.
515447
Follow Up By: Skippy In The GU - Thursday, Jul 26, 2007 at 08:27
I have 3 small small velcro strips on the top to stop
mine from falling down, I have a set which came with my Pop top
515563
Reply By: Member - RnR (NSW) - Thursday, Jul 26, 2007 at 08:07
Derek,
Great idea...I'm off to Bunnings today.
rnr!MPG:27!
254502
