G’day all,
I am after a clarification regards the effects of incorrect ball weight on a van.
I have a 16’-6” single axle van that weighs 1970 kg all up, with 1860 kg on the axle – ie there is 110 kg or 5.6% of the weight on the ball. I have a 4WD weighing over 2 tonne as tow vehicle, and I use a HR 250 kg weight distribution hitch.
I have read in many sources that the ideal weight distribution is to have 10 to 15% on the ball, with general comments about ‘better balance and control, less sway etc’ with weights in this range. I have not suffered any sway problems, but the ride has been quite ‘choppy’. The tow vehicle’s
suspension has recently been upgraded and is now a good deal stiffer, but I have not yet had a chance to see if this has improved the ride when towing. However, I am concerned that my light ball weight could be a contributing factor.
It will not be easy to alter the load distribution to increase ball weight as we do not have much heavy gear at the back. I have considered replacing the 60 litre
water tank with 80 L, and move it 600 mm forward (we generally run with full
tank) but this will only change the load to 6.3% as most of the added weight is still nearer the axle.
I have considered bolting a block of lead right up in the apex of the A-frame, but adding 40 kg there would only change the distribution to 7.1% which seems insignificant.
I would appreciate any comments regards the above situation. In particular:
* what are the symptoms of having too little weight on the ball?
* would changing the distribution by either of the two methods above (move
tank or add lead) have any real effect?
* any other
Many thanks,
glids
