need help-fusible links
Submitted: Thursday, Jul 26, 2007 at 17:43
ooze
Hi all, I've an '84 Pajero Superwagon that i'm fixing up and I'm sooo close to finishing. I need to replace missing fusible links on the +ve from the batt. There are two wires on both sides of the plug. I think one wire goes to the harness to the cabin and the other goes straight to the glow relay(?????). Anyway, does anyone know what size these links need to be, or, can they be replaced with inline blade fuses or those newer type of plug in fusible links, and if so, what size again? Thanks in advance, Paulo.
Reply By: TD100 - Thursday, Jul 26, 2007 at 18:04
dont use fuses,go to a good auto elec or supplier and prefab links can be purchased with lugs/connectors or link wire and make your own,as for current i would expect 40 or 50 amp wire would be needed.cheers Paul
254570
Reply By: DesF - Thursday, Jul 26, 2007 at 18:20
Hi .According to my info is as below:
2,3,4,5,6, Fusable link----- 80Amp
All the rest are multi purpose fuses
1,6,13,14,15,16,17,18 ----- 40 Amp
H/light 1,3,6. -----40Amp
Cheers "D"
254576
