Electric car radio aerials
Submitted: Thursday, Aug 02, 2007 at 17:23
ThreadID: 48327 Views:5530 Replies:9 FollowUps:4
My electric aerial will no longer retract fully, it goes down about halfway and then stops, I can hear the motor continuing to try and drive it down so I imagine it’s clogged with dirt. I’ve tried light oil, WD40 etc to no avail – does anyone have a magic trick for repairing them? otherwise I know it won’t be long before it’s snapped off in the bush by a passing tree.
Mike Harding
Reply By: Member - Michael J (SA) - Thursday, Aug 02, 2007 at 17:29
In the past a wash with soapy water and then polish has worked for me..and the aerial..lol
Hasn't got a kink in the aerial itself has it Mike?
Michael
AnswerID: 255504
Reply By: Mark & Jo, S/side, Bris - Thursday, Aug 02, 2007 at 17:31
Ours is dodgy to, you hear the motor trying to move it yeh but nothing happening. Disconnected it from the motor so didn't have to hear it and just leave it up, Been like that for the last year or so, the stupid thing is I know what is wrong with it and $15.00 down at Repco will fix it but its been over a year and I still haven't done it.. Yeppp... there's always next year....
Jo
AnswerID: 255506
Reply By: Johnny boy - Thursday, Aug 02, 2007 at 18:21
Hi Mike , Mate mine went crook on my 100 ser and I bought one from a spares shop the guy assured me will fit it was only about $40 but as always no fit for me!! well I took it back and went down to Toyota and $110 later all is tops ( for the last 2 yrs anyway ) well the problem was the long plastic or nylon track that runs inside the antena had broken in 2 places I could not replace mine but you may have the same problem so rip it out and check that if you can , I hope this helps??
Regards J.B.
AnswerID: 255516
Reply By: Nick R (VIC) - Thursday, Aug 02, 2007 at 18:31
I have a fix, it might not be exactly what you wanted nut they're tough as nails, for $14.95 you can get one of those rubber aerials and not have to worry about it again. I did that on the 80 and 60 series (neither were electric) and have not had another broken aerial. Days are numbered for the one on my gu, it goes most of the way down, a car wash will take it off one day
NickR
Carpe Cerevisi
AnswerID: 255518
Reply By: Member - 'Lucy' - Thursday, Aug 02, 2007 at 19:14
When we have had this problem at work, we just take the said vehicle to a car wash and put it through with the aerial up.
The Car wash usually tears it clean out and mangles it the same time.
Then take the vehicle down to contract maintence group ( Dealaship of vehicle make) and they promptly remove dead item and replace with an OEM.
No problem at all.
AnswerID: 255523
Follow Up By: Muddy doe (SA) - Friday, Aug 03, 2007 at 19:09
Sounds like the sort of publicly funded solution prevalent at MY place of employment!
FollowupID: 516844
Reply By: Shaker - Thursday, Aug 02, 2007 at 19:33
Mike, it will almost certainly be very slightly bent.
I have fixed plenty of these in the past, if you are going to any where near the Marina on Sunday, call in & I'll have a look at it.
AnswerID: 255525
Follow Up By: Mike Harding - Thursday, Aug 02, 2007 at 20:06
Thanks Shaker, much appreciated - I'm heading in the opposite direction this weekend but I'm sure I'll be in your neck of the woods before too long :)
Mike Harding
FollowupID: 516682
Reply By: blue one - Thursday, Aug 02, 2007 at 21:02
So many possibilities with a statement like that, though I won't bite. LOL
AnswerID: 255545
Follow Up By: Mike Harding - Thursday, Aug 02, 2007 at 21:15
Oh I see... you're drawing a simile with male penile erection problems - most amusing.
Mike Harding
FollowupID: 516690
Follow Up By: blue one - Friday, Aug 03, 2007 at 18:39
Not really Mike it was more along mechanical issues.
Strange analogy!
Want a cuddle? LOL
FollowupID: 516839
Reply By: Richard W (NSW) - Thursday, Aug 02, 2007 at 22:53
After I broke two aerial masts and bent the housing I replaced the whole thing with one of the short rubber bendy aerials.
AnswerID: 255574
Reply By: Brooka27 - Sunday, Aug 05, 2007 at 10:12
Mine was doing the same, they use a dry lubricant as in graphite powder normally.
You will have to use some type of cleaner to remove the oil lubricant you have used prior. Extend the aerial fully and make sure it has dryed extremely well, now rub some graphite powder onto the shaft segments dont go over board.
give that a go and see what happens!
Regards Brooksie.
AnswerID: 255891
