Monday, Aug 06, 2007 at 02:38
Wetfeet.
Do not despair.
When I fitted
mine I started on a Friday evening for a job that should not have taken any more than an hour as I had the CAV units already mounted on the bracket and hoses attached.
So it was remove the OEM pack and bracket, replace with CAV kit, connect hoses, prime and away I go.
Midnight Sunday night I gave up in despair. Could not get any
fuel into the first unit - the agglomerator.
I tried and checked everything I could think of, including pressurising the
fuel tank to force that green pee through - all to no avail.
MONDAY - rang the supplier who I know very
He couldn't believe it and said I'll come around on the way home, which he did.
First thing he did was pull the agglomerator apart (One more step than I did because I didn't know of or about the the next dissassembley step)
Yep! missing seal.
Cut a long story short, the guy who assembles the components for the importer had somehow forgotten to place the seal in this hidden spot.
Anyway once replaced, bingo!
fuel starts to Vac up, however there are some leetle bubble streams in the filter glass bowl while the engine is running.
Turns out that all the assembly - disassembly that I had done on Sat & Sun to try and get the mother to Vac/prime the line, had worn/damaged a couple of the seals.
So he said he would fix things and the next day turned up with an envelope full of every size seal used by those units, including the copper seals for the 'banjo bolt' full connections. (last me a life time) (LOL)
Haven't had a problem since.
Soooooo! in your case I'm betting it is leaking air. Less that an ant fart can affect it (LOL)
There are five seals in the CAV unit.
(1) Identify that their are five in your unit
(2) The two large seals that go top and bottom of the filter pack are different in size. Check that you have them in the right configuration.
(3) There is a large O-ring that fits around the centre inlet pipe, between the CAV header and the filter top (approx 16-20mm in dia)
The three seals mentioned in (2) & (3) above are the only ones tha come in the filter box.
(4) There is and must be a seal on the bottom drain plug.
(5) There is and must be a little O-ring seal on the top of the unit where the retaining bolt (around this bolt) where it inserts into the subject unit and holds all the components together.
I am having a guess that (1) the two large seals are A*** about face and/or one of the other three seals is missing or damaged.
(6) Ensure that once you have assembled the unit, that you can blow air through it from one side to the other.
When sealed and unencumbered by any blockage it takes only the minutest of Vacuum to draw the
fuel up, into and through a CAV Unit.
You said you 'oiled' the seals. They should go on dry. Firstly hope you didn't use real oil, but diesel. Secondly should go on dry.
Hope this helps
517140
