80 series in Japan
Submitted: Tuesday, Aug 07, 2007 at 01:38
ThreadID: 48481 Views:2563 Replies:5 FollowUps:7
Hi all, im currently in Japan on a extended business trip and I’ve picked up a 1992 80 series turbo diesel, 130000 on the clock, Yes it has all the bells and whistles and I got it for $12000 AUS, All is good and solid, I had Miyagi Toyota run a check and it came back with a clean bill of health, I was a bit surprised at this because at night I can see a whitish smoke floating around the back of the car and when I take off, I feel like the bat mobile, if I stab the accelerator a few times in neutral when I am stationary it stops and when I’m motoring along there is no smoke, I can only see it at night.
I guess some would say the fuel injection pump is wound up a tad too much and I’m over fuelling and the injectors need a clean out, advice from the boys at ARB, thanks.
But some would say the turbo, but it smokes at idle?
I’m in Japan and the Yard I bought the car from will fix it but they are not sure what the problem is, or don’t want to know.
This is my first post here, I am a west Aus boy, and had a troopie before i headed here, I took it everywhere and miss Aus so much, I hope I have posted this in the right place and I look forward to hearing any comments, cheers adam
Reply By: traveller2 - Tuesday, Aug 07, 2007 at 08:03
I wouldn't get too concerned as they smoke a bit when you boot them or are pushing hard up hills.
Night time isn't the best time to check for smoke as it shows up in the lights but may be nearly impossible to see in daylight.
Are you bringing it back to OZ? if so might be worth getting it looked at when you get home.
AnswerID: 256202
Follow Up By: Adamjapan - Wednesday, Aug 08, 2007 at 13:24
Hi, im here for another 5 years, thanks for the reply
FollowupID: 517445
Reply By: Member - Karl - Tuesday, Aug 07, 2007 at 09:42
Adam,
Another good site if you are arfter specific 80 Series info is www.offroad80s.com - it's an Australian site and someone there may also help you.
IMHO - I have always been advised that if there is white smoke from a turbo (diesel) it usually means that there is an issue with the turbo - in that oil may be leaking into it etc but this should occur all the time. Maybe what you are seeing is condensation if it is only at night.
Karl
AnswerID: 256218
Follow Up By: Adamjapan - Wednesday, Aug 08, 2007 at 13:31
thanks for the link Karl, yes the smoke isnt all the time, maybe it is the turbo though, because when i came to a stop I rev the motor twice and the smoke stops, maybe it burns that oil away when i do that, well next week it will go in for a injection clean and a turbo check , thank god im not paying.. thanks for the reply..
FollowupID: 517448
Follow Up By: Member - Karl - Thursday, Aug 09, 2007 at 09:50
Adam,
It might be a very small oil leak with the oil pooling whilst you are at idle.
Goo didea to have the injectors service and tuned (that is rest set so they are working properly and spraying the diesel in a fine mist and not squirting it in), also have them do your fuel pump at the same time as the pump and injectors go hand in hand.
These are the first areas that someone with a diesel should look at when wanting more power.
When they do your turbo have them check its boost setting - you don't want it to be too high. The average setting for daily driving should be around the 9lb (sorry about the imperial measurment) and no more than 12lb.
Hope this helps and all works out for you.
Karl
FollowupID: 517601
Follow Up By: Adamjapan - Thursday, Aug 09, 2007 at 14:59
Hi Karl, Sorry, where would the oil be pooling? It stops smoking when I rev the motor a few times.
ad
PS thanks for the link to the other site and the Welcome.
FollowupID: 517644
Follow Up By: Member - Karl - Thursday, Aug 09, 2007 at 20:52
Adam,
I am not exactly sure but I have been informed by my mechanic that oil can pool in the bottom of the housing where the tubine fans are - sorry I can not be more specific - I am mechanically technically handicapped :-)))
As it is not blowing smoke constantly I don't think it can be to great of a problem - yet, so it is good that you are getting your mechs to check it out.
Karl
FollowupID: 517698
Reply By: Al-one - Tuesday, Aug 07, 2007 at 09:49
Admamjapan,
It's usually black smoke if the fuel pump is over fuelling. Blue (white?) is burnt lubricating oil and on startup usually indicates that your valve stem seals are worm. The requires the head to be removed. While you are at it you normally recondition the whole head. Bit unusal at 130ks though providing you can belive it. I would be getting the work done by the supplier for nothing rather than spending the money back over here.
Al-one
AnswerID: 256220
Follow Up By: Graham & Lynne - Tuesday, Aug 07, 2007 at 22:00
valve stem seal can be done without taking head off.
from Graham
FollowupID: 517379
Reply By: Adamjapan - Wednesday, Aug 08, 2007 at 13:20
hi all thanks for the feed back, i wont be bringing it back to Oz soon, as i am here for another 5 years.
Yes it is a bit strange it only been able to be seen at night, i will have the turbo looked at and go for the injector clean, as for condensation, im not sure, it is about 32 degrees here at the moment (Sendai city) thanks for the link to that 4x4 site, I will post the answer after the servicing. cheers to all.
AnswerID: 256399
Reply By: Member - bushfix - Wednesday, Aug 08, 2007 at 13:35
g'day mate,
is there much opportunity (land) to go 4bying in over there? Another five years for a West Aussie, ooooh not me thanks.
Hope it all gets sorted, could be burning oil, Bilbo would know with his diesel experience.
AnswerID: 256405
Follow Up By: Adamjapan - Wednesday, Aug 08, 2007 at 13:42
HI, Yes there is lots of places to get stuck and a lot of 4x4 clubs, the worst thing of all is that you are never alone, not like in the west, going a week and seeing nobody wasnt strange but here going an hour or so..I will try and send an email to Bilbo, thanks for that and i too hope i can get this sorted, cheers ad.
FollowupID: 517449
