Australian equivalent of american wiring guage
Submitted: Wednesday, Aug 08, 2007 at 20:00
Member - Peter R (QLD)
Trying to track down a possible wiring problem with my Tekonsha Prodigy brake controller and see that the Minimum wire guage (in instructions from USA ) is for 14 GA.
Anyone know what the equivalent guage is in Australia?
Pedro
Reply By: Matt(WA) - Wednesday, Aug 08, 2007 at 20:21
Hi Pedro,
Someone supplied me with this link off the site a while back. I think GA is AWG?
http://www.vandenhul.com/artpap/awg.htm
Hope this helps,
Matt
256498
Reply By: Member - Ian F (WA) - Wednesday, Aug 08, 2007 at 20:23
Hi Pedro,
check out this site
http://www.batterypower.com.au/battery_wire_gauge.htm
Ian
256501
Follow Up By: Member - Peter R (QLD) - Wednesday, Aug 08, 2007 at 21:13
Thanks Matt and Ian, that looks like the chart I need .
All I need now is to understand what it all means.
Pedro
517539
Follow Up By: drivesafe - Wednesday, Aug 08, 2007 at 21:47
Hi Peter R, the first column is the G cable size and the 4th column gives you the mm2 size, so your 14G cable is 2.08mm2 which is just a bit thicker that 4mm automotive cable ( 1.85mm2 )
If the instructions state the minimum cable size is 14G then the nearest cable size above that would be 5mm automotive cable ( 2.9mm2 )
Hope this helps, cheers
517553
Follow Up By: Member - Peter R (QLD) - Wednesday, Aug 08, 2007 at 21:51
Drivesafe , your a champion.
Pedro
517556
