Brake Controller for caravan
Submitted: Wednesday, Aug 08, 2007 at 20:17
ThreadID: 48546 Views:6821 Replies:10 FollowUps:8
Hi all,just about to get ourselves a new van with electric brakes but i need to fit a brake controller to the 100 series,what have people got and what do they think of them(price/performance etc)as i need one shortly ,the van will be a jayco thanks Paul
Reply By: Member - lyndon K (SA) - Wednesday, Aug 08, 2007 at 20:20
Hi Paul
We are picking up our new van next week, for what it's worth i have heard that the Prodegy is a good unit, better than the Voyager one.
Cheers Lyndon
Now is the only time you own
Decide now what you will,
Place faith not in tomorrow
AnswerID: 256495
Reply By: Member - John T (NSW) - Wednesday, Aug 08, 2007 at 20:37
Evening Paul
I have a Trak Shak CT with leccy brakes and bought the Prodigy model - love it - easy to adjust to weights etc. I believe that Tekconsha (spelling) is releasing a new model. Try the directory list and contact Derek from ABR
John T (Lifetime Member)
VKS-737 Mobile 2619
Selcall 2619
AnswerID: 256503
Reply By: AdrianLR (VIC) - Wednesday, Aug 08, 2007 at 22:04
There was a recent discussion in thread 48405
Our Prodigy works very well
Adrian
AnswerID: 256520
Reply By: White Knight - Wednesday, Aug 08, 2007 at 23:15
Give Russell a call at Electric Brake Specialist. His located in Holden Hill, SA and is a expert in electric brakes. 82630600
AnswerID: 256533
Reply By: Geoff M (QLD) - Thursday, Aug 09, 2007 at 08:32
I'd go with the Prodigy too. Had one for almost 3 years now without any dramas and used over some pretty rough tracks.
Geoff
AnswerID: 256558
Reply By: Wizard1 - Thursday, Aug 09, 2007 at 08:48
Over the last several weeks I've noticed an increase in the amount of Prodigy problems posted on RV and caravanning forums.
Some seem wiring related ,others about draining batteries.
I considered changing my Hayman Reese to a Prodigy, but I think I'll stick with the devil that I know has worked well on 3 different cars for over 6 years.
AnswerID: 256561
Reply By: yakodi - Thursday, Aug 09, 2007 at 10:45
ABR generally have the best priced Prodigy brake controllers - As we have just replaced our hayman reece controller after 3yrs. Prodigy works very well/ simple to install.
AnswerID: 256575
Reply By: Member - Debbie R (SA) - Thursday, Aug 09, 2007 at 11:22
Hi Paul
Myself and everyone else swears on the Prodigy, I believe it is the best, consider also before you decide, Techonsia has problems with Cruisers and Prados, they work for a while then give up the ghost due to back feed, I had mine replaced and have had no probs since.
Barry
AnswerID: 256580
Follow Up By: Member - bushfix - Thursday, Aug 09, 2007 at 11:30
G'day Barry,
"back feed", could you elaborate mate? Is it with all Prados or just a particular series? Keen to know thanks.
FollowupID: 517611
Follow Up By: Member -Dodger - Thursday, Aug 09, 2007 at 16:55
The mistake in the mentioned vehicles is that the pick up from the brake light is taken from the pedal switch when it should have been taken from a rear brake light wire.
I have had a prodigy for around 6 years without any problems. I often tow vans other than my own and find it easy to adjust to the weight and braking power of these other vans.
I would certainly recommend one.
Cheers Dodg.
FollowupID: 517658
Follow Up By: Member - Debbie R (SA) - Thursday, Aug 09, 2007 at 17:28
Hi Bushfix,
As was explained to me, when my Techonsia failed, and excuse me if I seem a little vague due to not being my field of expertise, there is something about Cruisers and Prados systems that Techonsia after about 12 months of use there is a build up of energy which eventually flows backward when the brakes are applied. I don't know if I have explained this properly but I was under the impression that it was reasonably common knowledge, particularly with brake experts and other 4x4 parts dealers such as ARB, etc.
BARRY
FollowupID: 517665
Follow Up By: TD100 - Thursday, Aug 09, 2007 at 18:36
Hey Dodger,i cant see the difference in connecting it to the switch or the tail light as they both are on the same bit of wire?can you possibly elaborate as it is going in a 100 series cruiser cheers Paul
FollowupID: 517670
Follow Up By: Member -Dodger - Thursday, Aug 09, 2007 at 20:01
The feed from the pedal switch also goes to the cruise control and in some vehicles to the engine management system in the fly by wire vehicles thus when connected to the rear brake wire after any of these connections fixes the problem. As is the case in some Ford Falcon models. That is why they suggest to connect it near the rear stop light. These instructions usually come with the Prodigy.
Cheers Dodg.
FollowupID: 517684
Follow Up By: garryk - Thursday, Aug 09, 2007 at 20:06
G'day TD100
I think I can answer that one
The difference is that there is a computer involved , the stop light switch signal will also go to this computer because of ABS brakes and cruise control ect.
The stop lights and wiring adjacent are the last in line and post computers
Haveing brake controller before computer can cause issues
Garry
FollowupID: 517689
Follow Up By: garryk - Thursday, Aug 09, 2007 at 20:10
opps looks like Dodger replied while I was typing slowly
If you want MAJOR headache and cost ask your local auto elect what is involved in fitting up a LandRover Discovery 3
I am told a very costly black box is needed
Garry
FollowupID: 517691
Follow Up By: Member - bushfix - Friday, Aug 10, 2007 at 06:56
Thanks Barry, I will send an email to Tekonsha to see if they can elaborate.
Thanks Dodger, when I installed my, I found the multi-wire socket at the kick panel that heads to the rear of the car, simply tinned the red wire off the prodigy and fed in in the rear of the socket at ther relevant (brake light) wire, it sits in there nice and snug, too easy!
FollowupID: 517739
Reply By: Axel [ the real one ] - Thursday, Aug 09, 2007 at 17:20
Hayman reece, easy to adjust and will fit nicely into the ashtray space and still be easy to reach , no known problems either.
AnswerID: 256622
Reply By: Johnny boy - Friday, Aug 10, 2007 at 08:12
Gday mate , I have 100 ser and I agree ( PRODIGY) it fits nice and works a treat with no problems !!
Regards J.B.
AnswerID: 256669
