How long does your dual fuel stove take to boila typical 1ltr billy?
Submitted: Wednesday, Aug 08, 2007 at 20:26
Ron173
After some recent parts replacement with my 414 powerhouse coleman dual fuel stove, all is working good.
However I decided to see how long a billy (std 1ltr job) took to boil on the main burner at full tilt.
I had the lid off so I could see and it took 7 mins 30secs.
Has anyone else compared this, that was on coleman fuel.
Any different on unleaded?
They quote about sub 4 mins! must be laboratory?
Ron
Reply By: Member - John T (NSW) - Wednesday, Aug 08, 2007 at 20:34
Evening Ron,
I have a P/house but must confess I've never bothered to time the billyboil. I am probably doing other stuff while I wait and not in all that much of a rush but you have piqued my interest now and will time it next time out - early next month on the central Coast of NSW - so it will be faster there than at home cos it will be warmer haha
| John T (Lifetime Member)
VKS-737 Mobile 2619
Selcall 2619
"Argue for your limitations and sure enough they're yours" - Richard Bach in "Illusions" Lifetime Member My Profile My Blog Send Message |
256502
Follow Up By: Member No 1- Thursday, Aug 09, 2007 at 07:55
a watched pot never boils...didnt you mum ever teach you that...so its best if you do something else while its getting hot
517593
Reply By: Member No 1- Thursday, Aug 09, 2007 at 07:53
did you start with hot or cold
water
if it was boiling hot to start with ..i think something maybe wrong
if it was only hot i still think something could be wrong
if warm....mmmm
if cold...
well, i dunno
if freezing cold ...you did say you had it at full tilt...does that mean you were on an incline or the valve was opened fully and at maximum
tank pressure...not too sure what you mean here old boy
its a tad hard to answer Ron, with out knowing the following
at what temperature was the
water when you started?
I wont even ask about sea level thingy
but one thing i have noted with
mine is that the support plate seems to be a lot higher above the burner than on gas stoves...this too suggests that it may take longer as more heat escapes from under any pots etc.....also a high pot will lose more heat while its getting hot compared to a low wide one....
256555
Follow Up By: Ron173 - Thursday, Aug 09, 2007 at 09:42
Nudie,
Started with totally cold
water.
Dont know sea level but not greatly elevated.
full tilt / max noise / flat chat / high flame.
Dont think there is anything wrong with it was just curious as to how long others take.
7.5 mins is a long time to wait on tea in morning! but better than waiting on a gas bottle defrosting though.
Ron
517600
Reply By: Member -Signman - Thursday, Aug 09, 2007 at 09:17
Also, at a higher altitude- it would take longer to boil than (say) at sea level.
256564
Follow Up By: OnYaBike (Cairns, QLD) - Thursday, Aug 09, 2007 at 16:16
I always thought at a higher altitude (less pressure)
water "boiled" quicker because the bubbles could form more easily but the boiling temperature would be less than 100 degrees C.
But then it's a long time since High School physics. Must ask Dr Karl.
I think for practical purposes altitude isn't going to make an appreciable difference.
517654
Follow Up By: Member No 1- Thursday, Aug 09, 2007 at 20:01
ya wrong signman
your right onyabike but not for the resons you give
517685
Reply By: Member - MrBitchi (QLD) - Thursday, Aug 09, 2007 at 10:46
"I had the lid off so I could see"
It will boil much quicker with the lid on.
256576
Follow Up By: Ron173 - Thursday, Aug 09, 2007 at 21:00
Agree, but then you dont know the point it boils at, plus dont think it accelerates it that much.
Ron
517702
Reply By: Wizard1 - Thursday, Aug 09, 2007 at 12:22
Measuring how long it takes
water to boil. Ummm some issues there I think.
Perhaps we could try and get an idea how long paint takes to dry.
GAL.
256587
Follow Up By: Ron173 - Thursday, Aug 09, 2007 at 14:27
Well after some recent parts being replaced i was keen to see it was performing correctly.
hows your paint
517637
Reply By: Kev M (NSW) - Thursday, Aug 09, 2007 at 13:52
Where's Robin when there is something to be investigated :))
Kev
| Russell Coight:
256591
Follow Up By: Member No 1- Thursday, Aug 09, 2007 at 20:02
ditto
517687
Reply By: SKP - Thursday, Aug 09, 2007 at 16:11
I ran some tests on different stoves some time ago.
The Coleman Dual Fuel Feather Hiker running on ULP took 4mins 30 secs to boil 1L of 20C
water at 20C air temp at sea level (still air) 200mm dia. billy with lid on.
Takes slightly longer on Shellite
Water boils at a lower temp at altitude (you can't
cook potatoes on top of high mountains)
256613
Reply By: Member - cuffs (SA) - Thursday, Aug 09, 2007 at 16:20
With so much info, I won't be able to boil the billy again without a stop watch jezzzzzzzzzz!
256615
Reply By: Member - Willie , Epping .Syd. - Thursday, Aug 09, 2007 at 17:45
What kind of billy . A nice shiny stainless steel one takes longer than I nicely blackened jobby .
Willie.
256627
Follow Up By: Ron173 - Thursday, Aug 09, 2007 at 21:20
Well another interesting point there,
mine is a fairly new replacement, so is shiny a bit.
never knew it was a factor?
so there you go, forumites provide info again.
Rgds
Ron
517705
