I'm on one side of the hill, technology is on the other side
Submitted: Thursday, Aug 09, 2007 at 21:07
Member - Kim M (VIC)
I'm just about to put money down on a Off Road trailer. It comes with an 80 amp hour battery charged from the car.
However, I have a 80w Solar Panel and a 2 KVA Honda generator. What "black box thingy" do I need to charge the battery from these two units?
Kim
Reply By: RustyHelen - Thursday, Aug 09, 2007 at 21:13
Kim
Get on to the yahoo campertrailers group. The
forum there will give you all you need to know. Word of advice though don't post with words "12 volt" in the title as this usually attracts a lot of traffic.....
Rusty
256649
Follow Up By: Member - Kim M (VIC) - Thursday, Aug 09, 2007 at 21:15
Thanks for that. I'll have a look.
Kim
517704
Reply By: Gronk - Thursday, Aug 09, 2007 at 23:35
You need two thingies !! A solar regulator and a 3 stage ( preferably ) batt charger !!
256658
Reply By: Mainey (WA) - Friday, Aug 10, 2007 at 08:43
Kim,
Question:
(a) do you have a dual battery system in the car ??
(b) do you also have a Solar REGULATOR ??
256675
Follow Up By: Member - Kim M (VIC) - Friday, Aug 10, 2007 at 17:53
Mainey
Yes, to both of your questions.
After a few phone calls today, the battery charger questions has been answered.
The Solar panel has an Anderson plug fitted, but I'm not sure how to connect it via the trailer wiring to the battery.
Kim
517834
Follow Up By: Mainey (WA) - Sunday, Aug 12, 2007 at 16:55
Kim, it has to be an independent cable running from the (+) Aux battery terminal in the vehicle, to the (+) Aux battery in the CT via an Anderson plug at the tow bar and back to the (-) negative terminal of the vehicle Aux battery.
Connect the Solar panel via the solar regulator, to the Aux battery (pos & neg terminals) in the vehicle first, then parallel wire this battery to the Camper trailer battery.
Don't use the 'normal' trailer wiring loom or 5 or 7 pin connector as the battery cable has to be capable of going the full distance from end to end with ZERO voltage drop, so it has to be "thick" just how thick depends on the total distance.
The vehicle Aux battery and Camper Aux battery will be charged by the vehicle when driving and by the Solar panel when stopped (in the sun) and the two batteries (when connected together) will run all your electrical accessories, using lesser percentage of each battery, making charging faster and leaving the Cranking battery only for starting.
518064
Follow Up By: Member - Kim M (VIC) - Sunday, Aug 12, 2007 at 18:02
Thanks Mainey
I've taken a copy of your response and will talk to the auto guy next week.
Kim
518077
