pajero fuel pump
Submitted: Friday, Aug 10, 2007 at 21:51
jonl
G’day
Has anybody had a problem with
fuel injection pump with a pajero DID.
We were on our way back from
cape york almost made it home then the engine stopped while doing 100km on the highway, the electronic
fuel pump had to be replaced (the immobilizer switch from what I can make out)
Reply By: jon p qld - Saturday, Aug 11, 2007 at 07:25
Most of the new electronic
fuel pumps are very prone to
water damage, as in
water in
fuel. I haven't had to replace a Pajero one yet but have replaced numerous Patrol ZD30 pumps and also Rodeo's. It's not a cheap job either !!
256790
Follow Up By: jonl - Saturday, Aug 11, 2007 at 08:49
is there a
fuel filter that will take out the
water?
517882
Reply By: Member - DOZER- Saturday, Aug 11, 2007 at 15:29
I have heard on here b4 that running a paj did out of
fuel blows the pump aswell....so a blockage in the lines due to algai would do thesame im guessing....and algai comes from
water in
fuel....make sure you get those lines checked thoroughy...and use some algai treatment to be sure.
256816
Follow Up By: Member - Scoof (SA) - Sunday, Aug 12, 2007 at 22:22
Dozer I havent heard about running a paj out of
fuel blows the pump , are you talken DiD .I have done it a few times and so far all is good.
May be I shouldn't do it anymore??
Cheers Scoof..
518131
Follow Up By: Member - Scoof (SA) - Sunday, Aug 12, 2007 at 22:23
Cheers Scoof..
518132
Follow Up By: Member - DOZER- Monday, Aug 13, 2007 at 07:06
A search thrugh the arcives should find the post...maybe the person who had to buy a new pump was just a one off...its impossible to draw conclusions from one occurance, and your experience seems to blow that conclusion out of the
water..
Andrew
518147
Reply By: jonl - Saturday, Aug 11, 2007 at 16:20
That might have been some of the problem as the
fuel was very low when it stopped. (
fuel light was not on)
256821
Reply By: marq - Saturday, Aug 11, 2007 at 16:24
TIme to get a long range
fuel tank 81L from LRA are good.
256822
256823
TIme to get a long range fuel
256824
