Custom made poly water tanks
Submitted: Saturday, Aug 11, 2007 at 19:46
Member - Duncan W (WA)
Further to my previous post regarding my Desert Trip Prep, another option to carrying
water drums from the
supermarket or jerrycans of
water would be to get a custom made
water tank to fit in the back of my vehicle. All of the off the shelf tanks are either too small to be of much use or too wide. If I can get one to my own measurements I can easily get 150L with a 250mm high
tank.
There is a firm in Midvale (ROTA MOULDINGS), that make the tanks. Before I phone them next week has:
a) anybodyy had a custom
tank made?
b) what sort of cost above the standard
tank prices would I be looking at? and
c) any other company's in
Perth make polyethylene tanks?
Reply By: Kev M (NSW) - Saturday, Aug 11, 2007 at 19:58
Duncs,
Check this post out
Look Here
Cheers Kev
| Russell Coight:
256853
Follow Up By: Member - Duncan W (WA) - Saturday, Aug 11, 2007 at 20:24
Thanks Kev, that is an option as
well, will obviously then have to build a false floor. Abvantages of the bladder is that I can fold it up when not in use and easier to store.
517951
Follow Up By: Kev M (NSW) - Sunday, Aug 12, 2007 at 07:04
Duncs,
If money permitts you could get a
fuel one made as
well and have both under a false floor.
Cheers Kev
| Russell Coight:
518009
Reply By: KiwiAngler - Saturday, Aug 11, 2007 at 20:01
It may prove costly to have a 'one off '
tank made
Rota Tanks are made using the 'low pressure rotation method'
To do this you must have a metal mould into which you put PE resin then introduce the entire mould into an oven at about 260c and rotate it until the resin mellts and coats the inside surface of the mould
The cost to build a'one of mould' to make your
tank MAY prove too high
256854
Follow Up By: Member - Duncan W (WA) - Saturday, Aug 11, 2007 at 20:26
Yer that's what I heard this morning when I picked up their brochure from one of the 4WD shops. Unfortunately I haven't won Lotto . Also using the drums from the supermarkets will cost about $75 and if one drum gets a leak all I'll loose is a small percetage and not 100%
517953
Reply By: Trevor R (QLD) - Saturday, Aug 11, 2007 at 21:02
Duncan,
Boab 4x4 here in Lawnton (Nth Brissy) have an off the shelf resin
water tank that fits behind middle
seat of Patrols holding about 55 or 60 lts off memory for about $350. Don't know if they stock for other vehicles but I could find out if you want. May be another distributor over your way???? All prices and capacity is just off memory so I maybe a little out in my figures.
Trevor.
256866
Reply By: DIO - Saturday, Aug 11, 2007 at 21:23
Duncan, you might have already hit upon the reality of 'a your eggs in one basket' and the containers might wel prove to be the best investment in the long run. heaps cheaper too. Best of luck with your trip.
256870
Reply By: _gmd_pps - Saturday, Aug 11, 2007 at 21:58
make one yourself .. easy ..
get 100mm drainage pipe and a bunch of ts and knees
.. put together a few length of pipe in the form you can fit ..
glue it together with a drain and a fill connection ..
there are also readily available braces for 100mm pipe to hold
it in place .. cheap.. easy .. flexible ..
have fun
gmd
256876
Follow Up By: V8 Troopie - Sunday, Aug 12, 2007 at 00:59
Yes, but it's just about the most inefficient waste of space when it comes to
tank volume. A rough calculation tells me you need about 1.5m of 100mm drainage pipe to hold 10 litres.
So, for a reasonable
tank capacity, say 50 litres, you need 7.5 metres! of this pipe in the back of the car.
That equates to a lot of elbows, tees, etc and by then its no longer cheap IF you can find the room for all that pipe stuff.
Klaus
518004
Follow Up By: _gmd_pps - Sunday, Aug 12, 2007 at 01:24
well .. for 80l I needed 4 lengths with 4 ts and 4 ellbows ..
and 2 ts for drain and fill .. I find that pretty cheap ..
each length is about 2.4 m and running along the bulk head of the bed ..
if you have a tiny car you need a lot of ellbows, but then
again a thermos bottle might do ... rofl ..
have fun
gmd
518007
Reply By: Footloose - Sunday, Aug 12, 2007 at 08:05
One of the biggest advantages of carrying
fuel and
water in smaller containers is the ability to lighten the load when bogged or hung up.
256898
Follow Up By: Member - Duncan W (WA) - Sunday, Aug 12, 2007 at 18:05
Now that would be an advantage.
518079
Reply By: Member - Mick O (VIC) - Sunday, Aug 12, 2007 at 09:58
Dunc,
have you checked out any of the caravan supply
places. Carac or similar. I was looking for much the same prior to this years trip and the variety in shape size and capacity of the caravan
water storage tanks is incredible. I ended up getting one of the 60 litre flat poly tanks from Opposite Lock for $290. It lays flat in the dual floor and I stacked food and equipment boxes on top. Very robust and did the job
Cheers. Mick
256907
Follow Up By: Member - Duncan W (WA) - Sunday, Aug 12, 2007 at 11:45
Hi Mick, I've already got a 55L OL flat
tank that fits either behind my drawers or against the front cargo barrier. OL do some other tanks but very expensive. The caravan
places are an Aladin's
Cave of stuff so might find something there. Basically I've got 500mm W x 1035mm L to fit one in.
518030
Reply By: aka_db - Sunday, Aug 12, 2007 at 16:57
Duncan,
I personally use injection moulded polyethylene containers which each hold 25l and are approx' 280mm x 280mm x 450mm (inc cap and handle). These fit in lots of locations, are easily transportable and best of all, readily available and cheap. I paid only around $10 each and have been using them for around 8 years now. the have a strong handle for carrying, a fitting for a tap in the base and a good strong screw lid with an excellent seal. These have done many km's in both back of ute and in Camper Trailer and have never leaked or cracked. I bought the ones made for carrying dangerous liquids as these were more robust. I especially like the fact that I can take as many or few as I think I need and if I have to carry them to a remote filling location I can easily one by one.
regards, DB.
256945
Follow Up By: Member - Duncan W (WA) - Sunday, Aug 12, 2007 at 18:04
Think I know the type you mean? Seen various sizes at Super Cheap and also the
camping stores.
518078
Reply By: Member - Bruce and Anne - Sunday, Aug 12, 2007 at 17:20
I just went out and measured the poly
tank I put in my camper trailer 830mmlx500mmwx200mmh and has a capacity of 87 litres. We have an Isuzu MU Wizard which is the same size as a Holden Frontera, so I measured the cargo area and could fit 2 side by side in there and at a cost of $100 each is pretty cheap. Put a false floor over the top and you only lost 200mm of floor space.
My 2 cents worth.
Cheers Bruce.
256948
Follow Up By: Member - Duncan W (WA) - Sunday, Aug 12, 2007 at 18:13
Thanks Bruce. What I might do is get another OL flat
tank and sit it over a false floor about 300 - 400mm up. That way I can still store
water drums under. We use the 15L drums at home so have a number of empty ones. Could just refill them from the tap.
In theory that will give me about 190 Litres.
Thinking also of getting a pressure pump fitted that way if I do happen to get a spinifex grass smouldering or small under body fire I will have a bit more hitting power. Will also carry of course a long wire hook and extinguishers.
518080
