Nissan 3.0lt 2002 Patrol
Submitted: Monday, Aug 13, 2007 at 14:22
T.D.
Anybody experienced broken rear spring hangers. I have just returned from a trip to the Gulf towing a camper trailer and tinnie and before leaving fitted airbags to the rear to level the rig up.On the way home the brake oil level light came on and called in to the Nissan dealer in Mooree but he was too buisy to look at the problem.On arriving home I took it to my usual serviceman and he reported that the back springhanger had broken and squashed both brake lines.
Nissan are not intrested The vehicle has done113000kls and is not at a Nissan dealers
shop.
Talk about get a run around,up till now I have been a real Nissan man but no moore
TD
Reply By: Member - 'Lucy' - Monday, Aug 13, 2007 at 14:33
TD
I have heard of something similar, however it hasn't been a spring hanger, it was the chassis rails above the airbags.
I had my Troopy up on a hoist some time ago having an extra airline installed at an ARB
shop and the fitter made a comment about my polyair (bellows).
Anyway during the conversation he stated that if the vehicle had been a Nissan he would have been looking for a crack in the chassis rail where the polyairs were fitted.
Then went on to say that Nissans were prone to cracking in this area when airbags were fitted.
So! as it seems that you haven't determined yourself what the problem is, it may be an idea to get a second opinion.
Whatever, it doesn't sound good and needs to be fixed, and if Nissan can point at the Polyairs as the cause then its going to be interesting.
Good luck in your dealings with them.
257062
Reply By: traveller2 - Monday, Aug 13, 2007 at 15:11
Quite often happens with GU's when fitted with heavy duty rear springs and /or airbags, both utes and wagons.
What happens is heavy springs or airbags allow the road shocks that are usually absorbed by the
suspension to be transmitted to the chassis and spring mounts which cannot handle the load and break off.
A friend had it happen to his GU, ended up being a body off the chassis job to repair it and very expensive as
Nissan won't want to know about it and neither will insurance.
The next problem may be finding someone that will repair it correctly as chassis repairs can be a fine art.
257069
257071
Reply By: Outbacktourer - Monday, Aug 13, 2007 at 21:03
T.D. Yes, this problem is not unknown. As a matter of interest, what PSI were you running in the Polyairs?
OT
257130
Follow Up By: T.D. - Tuesday, Aug 14, 2007 at 09:36
Thanks for the reply.
20psi was the pressure
TD
518317
Reply By: Leroy - Monday, Aug 13, 2007 at 21:24
hmmm
top spring mount bending up eh? Usually too stiff a spring but imagine too pumped up a poly will do the same trick! Something has to give and if the
suspension can't then the top mount bends instead. Not uncommon. A body off job as above sugested. One job the utes are easier at getting done as more access.
Leroy
257137
Reply By: GO_OFFROAD - Monday, Aug 13, 2007 at 22:07
they can even break the chassis off there, we fit braces to prevent this from happening, as it is common, normally first
sign is the chassis tapping on the floor, when they bend up.
257139
Follow Up By: greggu - Tuesday, Aug 14, 2007 at 21:09
gday go off road
i have just had my gu 2004 3.0 L td patrol wagon upgraded with heavy duty tjm progressive springs put on the back and front ( not progressives ) and do have the poly airs fitted already - so no probs i dont think yst as only done a month or two ago but very interested to know what i need to do to guard against this issue occurring - any recommendation as to who can strengthen this spring hanger support area and how - and maybe who to contact in
brisbane
my sincere thanks greg
518463
Reply By: Member - JohnR (Vic)&Moses - Tuesday, Aug 14, 2007 at 10:04
I concurr with Go-Offroad, I have a brace from side to side across the spring towers and even that has bowed. Have heard of quite a few. The first you notice is the spring towers bowing upwards on the inside, before the towers stretch the metal bracing, and possibly tear out of the chassis.
As suggested above, the polyairs, heavier springs put more direct shock straight into the chassis. Heavier shockers should help.
257183
Follow Up By: greggu - Tuesday, Aug 14, 2007 at 21:10
gday john same request as to go off road follows
brisbane
518466
Follow Up By: Outbacktourer - Tuesday, Aug 14, 2007 at 21:57
FWIW I've run around for 5 years with a H/Duty 2 inch lift, Polyairs (no more than 12PSI) and Koni's with Howing Moon on top, loaded fridge and _Affordable_Storage_Drawers.aspx in the back and off road trailer on the ball. (see rig picks). It's taken a few big
washouts to the point where the a&s has
well and truly been in the air. After hearing a few of these reports I got an engineer to check
mine out when I got a chassis extension/dual cab conversion recently, no issues found. FWIW they were pretty relaxed about it and told me they had seen the problem but only on vehicles heavily loaded with standard
suspension and upgraded my GVM to 3.5T with the
suspension combo I already had.
There was a report here a while back of someone who had this happen up at the Cape, also big load, standard
suspension.
OT
518489
Follow Up By: GO_OFFROAD - Wednesday, Aug 15, 2007 at 08:06
Ive only seen it with aftermarket
suspension.
And have seen the aftermath of one overloaded, with camper trailer, on a cape trip, that broke the chassis off completely at the spring mounts.
The nissan also has a problem with tearing the front spring hangers off as
well, had this happen to one on a recent canning trip, and while all the vehicles were being serviced in Alice, the 4wd workshop there reported welding 3 front spring mounts back into patrols this year, and abour bracing the rears, because the towers bend up.
518528
Follow Up By: Outbacktourer - Wednesday, Aug 15, 2007 at 09:02
Interesting, key message I guess is whatch those weights!
518547
Follow Up By: Member - JohnR (Vic)&Moses - Wednesday, Aug 15, 2007 at 09:20
I had the first correction at 13,000kms with only the Polyairs as my assistance at 25psi ! I think that road shocks and weights do it. I was interested at tthe comment on the front ends though GO_OFFROAD. I hadn't heard that one before.
I have made comments before about the shocks from tyres at high pressure that are also partly to blame - BUT the front towers and that have the shocks mounted through them. It wasn't a competition vehicle GO_OFFROAD? Perhaps I should talk more with the local racer too.
Greg, I just have a plate mounted side to side across the top of the spring towers at the rear - 1/2" thick and about 7-8" wide and bolted using the bolt holes in the towers, outside of
the springs. Its easier with a tray to remove it. Others have RHS mounted vertically side to side, but bolted in. That would be lighter.
518551
Follow Up By: Leroy - Wednesday, Aug 15, 2007 at 09:36
ARB are aware of the issue with putting in too heavy duty a spring. Mates GU is loaded with all the accessories including a Kaymar bar with twin carriers and 33" tyres. OME heavy duty springs sagged very early in the piece. Went back to ARB and the fella behind the counter was going to install the heavy duty springs off the ute and his collegue advised against it as it .....guess what..... bends the spring towers up. Since then OME heavey duty springs are like 21mm dia steel instead of the 19mm they used to be made of.
If the spring isn't going to absorb the impact something has to bend.
Leroy
518555
Follow Up By: Member - JohnR (Vic)&Moses - Wednesday, Aug 15, 2007 at 10:26
Just re-reading my response earlier, the 13,000 km reference was with the original equipment springs and I am also aware that others have had similar problems with the OE too.
Leroy, I have 21mm wire these days and that was before I started towing. Really good progression there still. Pretty happy with the
suspension and the way it handles weight and shocks. It really hit the bump stops with the OE and little weight. Does damage that way :-(
518572
Follow Up By: greggu - Wednesday, Aug 15, 2007 at 10:26
thanks for the feedback guys as i said no
sign of an issue with
mine yet but i believe in pre emptive action where possible - i did do the cape in 2006 towing my kk classic mariner and with 3.75m boat on top and with the patrol was defintely overloaded full roof rack and rear fully loaded also - with poly air bags fitted to level out the rear and thankfully no
sign of probs on that trip - but thats what decided me to get a 2 inch lift and the tjm progressive rears and standard fronts
suspension upgrade but i have to say the ride in town is now defitely rougher and harder particularly when unloaded so the perferct compromise never exists i guess.
- thanks very much john for the info i will investigate the bolt on rhs option - - also i have never heard of a prob with the front spring hangers before on patrols but had heard about the rear cracking once or twice but the posts i saw seemed to be with the utes not the wagons
thanks again guys see you greg
518573
Follow Up By: Member - John (Vic) - Wednesday, Aug 15, 2007 at 13:54
Didn't someone post some photos or a link to a web site with the photos of this issue on here sometime back?
518605
Reply By: GO_OFFROAD - Wednesday, Aug 15, 2007 at 13:54
we run our mount under the spring seats, across the front, gusseted to them, as there isnt enougth room to get a decent mount across the top of them on a wagon.
The fronts break when the section of gusset under the chassis coming out under the front spring upright mounts cracks, then the vertical sections tear away from the chassis, we weld in flat sections on 45 deg to double the strength of the fronts, and prtevent this from happening.
257356
Follow Up By: GO_OFFROAD - Wednesday, Aug 15, 2007 at 13:57
one thing most people seem to forget also, is that the vehicle is supposed to sit down in the rear when its fully loaded, when set up correctly up to 25-40mm, and should come back to around level after a week of drinking beer,
water, and eating food, and sitting aprox 30mm up in the rear when day to day around home, with the right rear spring, we dont recommend running any more than 10-12 psi in polyairs, if they are required, as an assist only fully loaded, so you can reduce pressure in them as weight comes off as
You also want a monotube type shock, when running air assist, so they can cope with the ever chnaging spring rate and stop the "bounce" air bags can create.
518606
Follow Up By: greggu - Thursday, Aug 16, 2007 at 19:34
thanks for the info go offroad re the reinforcing of the
suspension mounts for a patrol - any chance of a photo or two to have a look at showing what you do or perhaps even a rough sketch or two
my email is - matheng@bigpond.com
appreciate your feedback and any further info
my best regards greg
518829
