Calling all Mechanics the Paj has a starting problem
Submitted: Monday, Aug 13, 2007 at 19:24
GREENDOG
Ok can same one please tell me why the paj wo'nt start first go when the temp is 10 degress or lower,it takes me 3 to 5 times after waiting a couple of minutes between each go to get it started and when it does start it's like the motor is laking fuel as it builds up gradually to then normal idle.I have had the fuel pump replaced last year before my Gulf trip but it's all ways done this and only when it's cold so i really do'nt know what it could be.Any Thoughts,cheer's GREENDOG
Reply By: marq - Monday, Aug 13, 2007 at 19:54
Petrol ?
Diesel ?
LPG ?
Model ?
257114
Follow Up By: Voxson - Monday, Aug 13, 2007 at 20:46
Petrol 92'ish Manual
518268
Reply By: Matt(WA) - Monday, Aug 13, 2007 at 20:00
If its a diesel, glow plugs.
If its a petrol with a carby could be auto choke
If its a efi No idea.
Matt
257116
Reply By: Member - Roachie (SA) - Monday, Aug 13, 2007 at 20:11
Time for an upgrade to a good reliable Patrol Greendog....a 2000 model 3L diesel might be the go!!!! hahaha (sorry mate)...
257118
Follow Up By: GREENDOG - Tuesday, Aug 14, 2007 at 16:08
Hang on a minute did you say upgrade to a Patrol mmmm,Nah but if you lend me the money Interest free i'll go out and buy my self a CRUISER,LOL cheer's GREENDOG
518381
Follow Up By: Member - Pesty (SA) - Thursday, Aug 16, 2007 at 12:23
Calling in to the Kadina Show this weekend Greendog?
YP4WD club will have a stand there.
Cya then Pesty
518766
Follow Up By: GREENDOG - Thursday, Aug 16, 2007 at 16:05
Pesty what day is it on ? cheer's GREENDOG
518788
Reply By: Mark & Jo, S/side, Bris - Monday, Aug 13, 2007 at 21:02
We've never had starting problems with our paj no matter the temperature, do have to let her warm up for 5 minutes or so till you hear the idle drop and it seems to help the gearbox.
With the brains and braun of Pezza though it looks like we have finally found the problem we have been having with our paj since the fuel
tank was replaced. It would start no worries, then not start. It would turn over and want to fire but it was like the fuel just wasn't getting through.
Looks like we have determined that the problem is the plug connection on the fuel pump, since Pezza gave the connections a bit of a rough up with sandpaper on the end of a screw driver to clean the connections, she has been good as gold, not a problem at all. Since October last year we have had these problems, spent a fortune trying to figure the problem out, two new computers, our mechanic pulling whats left of his hair out and it looks like the whole problem was a simple plug, (I always said it has to be something small that is an oversight.)
Maybe check that out on yours? Easy accessed if you just unscrew the plate cover in the back of the paj.
Jo
257129
Follow Up By: GREENDOG - Wednesday, Aug 15, 2007 at 15:51
Thanks Jo i'll have a look at the connection and see how it starts after that,cheer's GREENDOG
518622
Reply By: Eric Experience - Monday, Aug 13, 2007 at 22:40
Greendog.
If its a fuel problem, one of the best things to check first is fuel pressure. Get some one to show you the test point for measuring fuel pressure and then get a gauge and measure the pressure when cold. At least then you have some facts to work with. Eric.
257146
Reply By: Member - MrBitchi (QLD) - Tuesday, Aug 14, 2007 at 08:56
Idle Stepper Motor?
Ask here....
http://www2.pajeroclub.com.au/forum/
257170
Follow Up By: GREENDOG - Wednesday, Aug 15, 2007 at 15:54
I had the Idle stepper motor checked out last Augast and it was fine cause the Paj justs about stalls on going back down through the gears when the air con is on another problem i have to look at any way thanks for your input.cheer's GREENDOG
518623
Reply By: Mark & Jo, S/side, Bris - Thursday, Aug 16, 2007 at 10:15
Any luck yet Greendog?
Jo
257489
Follow Up By: GREENDOG - Thursday, Aug 16, 2007 at 16:07
Having a look on the weekend
518789
Reply By: Mark & Jo, S/side, Bris - Thursday, Aug 16, 2007 at 10:16
Jo
257490
