Can somebody explain why this happened
Submitted: Thursday, Aug 23, 2007 at 22:19
ThreadID: 48980 Views:2703 Replies:4 FollowUps:2
A friend of mine has a Nissan dual Cab (diesel) which is around 18 months old with no off road work.
A few days ago it was a bit cold down here in the Village. He went out to the car in the morning (7am). Started it up, put the demister on, then went back inside for approximately 15 minutes.
When he got back to the car, a three inch crack had appeared on the windscreen.
I happened to ring him around 10.30am, and by that time the crack had increased to eight inches.
My first reaction was to berate him for using water too hot to remove the frost. However, this wasn't the case.
The windscreen also doesn't have any obvious stone damage.
I've done the same thing in the high country in far colder conditions than this over many years, and never had a problem.
Kim
Reply By: Hairy - Thursday, Aug 23, 2007 at 23:00
Gday Kim
If it happened in Scrubby Town I wouldnt be blameing the weather.....It would be a cultural problem??
Maybe a small unseen crack already just waiting for a change in weather to bare its ugly head???
AnswerID: 258697
Follow Up By: Member - Kim M (VIC) - Friday, Aug 24, 2007 at 16:26
Hairy
I had another look at it today. Definitely no stone damage.
Kim
FollowupID: 520156
Reply By: Member - Hayjude (NSW) - Friday, Aug 24, 2007 at 09:20
about 18 years ago it was cold and drizzling rain and I pulled up at the shop to return a video and had left the car running with the back window demister/heater on and while I was in the shop heard what sounded like a bomb going off. Ran outside and the back windscreen had bleep tered. Two toddlers in their car seats scared but OK. This was in my mitsubishi magna. Never did that again.
AnswerID: 258725
Reply By: Outnabout David (SA) - Friday, Aug 24, 2007 at 20:58
Kim,
When I was coming back from the EO Gathering I watched a rock comeup and mack the windscreen just at the bottom but didn't break and I thought at the time how lucky it was. Three weeks later same thing a frosty morning with demister on and a small cracked started and I knew it was right where that rock hit. ye the time I got to work (3Km) the crack had travelled full width of the windscreen. lucky it is below the wiper line so I will not hurry to replace it.
AnswerID: 258805
Follow Up By: Member - Kim M (VIC) - Friday, Aug 24, 2007 at 21:10
David
You could be right, but this has happened behind the protection of the wiper bar.
Kim
FollowupID: 520217
Reply By: Member - andrew B (Kununurra) - Friday, Aug 24, 2007 at 22:12
I recall dr Karl on JJJ explaining funny things about glass one day. From memory, the question was why do some glasses drop on the floor and not break, yet some break in your hands while washing up. It basically comes down to the straw that breaks the camels back. glass will eventually bleep ter just due to the atoms in the atmostphere crashing into it constantly, but it will take a hell of a long time. Every knock does some damage to the structure of the glass, a big impact may not break the glass, but will weaken it, and later it may be broken by a smaller impact.
In this case it may be as others have said, caused by a previous impact (not nesesserily in the same plase as the crack), or the windscreen may have been under some tension due to the way it was fited or chasis/body flex; the change in temperature may have been the straw that broke the camels back.
Cheers Andrew
AnswerID: 258812
