After Market cruise Conrol for 4.2 TDI Patrol
Submitted: Monday, Aug 27, 2007 at 18:50
ThreadID: 49069 Views:3804 Replies:4 FollowUps:2
Evening all,
I have looked in the archives but could not find the answer. Simple one I think - what model cruise control can I put in my 2005 Nissan Patrol - 4.2TDi. Nothing fancy - just 1 that will hold the speed I ask?
Answers gratefully accepted.
John T (Lifetime Member)
VKS-737 Mobile 2619
Selcall 2619
Reply By: macy - Monday, Aug 27, 2007 at 18:56
we put an AP60 on our HZJ79 Tojo I think it's very good hve done over 30,000 kms with it on, A lot of bush tracks and corrigations no probs. Cost about $190 for Kmart or Super cheep.
Cheers Mac
AnswerID: 259100
Follow Up By: Member - John T (NSW) - Monday, Aug 27, 2007 at 19:47
Thanks for the info Mac - I'll check out supacheep on Wednesday.
VKS-737 Mobile 2619
Selcall 2619
FollowupID: 520549
Reply By: Dusty2 - Monday, Aug 27, 2007 at 19:06
gday john, try supercheap autos. they have one for approx. $200 4wd monthly have done a piece on them recently .t ry there web site. steve.
AnswerID: 259101
Follow Up By: Member - John T (NSW) - Monday, Aug 27, 2007 at 19:48
Steve, Thanks for the info - as above I'll check it out on Wednesday.
VKS-737 Mobile 2619
Selcall 2619
FollowupID: 520550
Reply By: Brian (VIC) - Monday, Aug 27, 2007 at 23:34
John,
I put the AP60 on my Triton, despite the guys at Autobahn telling me that coz I have a turbo diesel and therefore have no vacuum pressure from the intake manifold it wouldn't work.
The trick with the cheaper systems that are vacuum driven (for the actuator assembly), is to take a feed off the vacuum line going to the brake booster FROM the vacuum pump, if you have one. Otherwise you will have to spend extra to get an electrically operated system.
Mine also gets its speed data from magnets attached to the tail shaft as apposed to the expensive units that take a feed out of the back of your speedo. 3 vehicles and aprox 200,000 km later I haven't had a problem with the unit yet.
Brian T
AnswerID: 259174
Reply By: Grungle - Tuesday, Aug 28, 2007 at 07:41
Hi John,
With the AusCruise vacuum operated cruise control on my TD42T Patrol, I did away with the small ball resevoir that comes with the kit and just tapped into the vacuum line from the vacuum tank with a T-Piece. There is more than enough volume in the tank to handle the cruise control. I also didn't bother with the magnets for the sensor but instead tapped a wire into the speedo sensor that comes out of the back of the transfer case. Most modern cars with electronic speedo's (not cable speedo's) can be done this way. Works a treat.
The only issue I had was that I used a live wire from the wiper motor for the power and everytime I put the wipers on, this wire was dragged low which cut the cruise control out. I have since rectified with any further issue.
David
AnswerID: 259180
