Friday, Sep 07, 2007 at 00:03
It might be worthwhile checking the Nissan handbook again because as general rule Nissan advise against fully synthetic oils in their diesel engines. For example on the ZD30 they advise against using any oil that exceeds CF-4 and there is a Nissan service bulletin that specifically warns against this. If they say in your handbook fully synthetic is OK
well that is fine then, but if not it would be a shame to save a few cents on
fuel consumption and then have to pay out big time for an engine rebuild. I am no lubrication engineer but in laymans terms it is to do with the higher compression pressures, piston ring materials and the fact the fully synthetic oils are in effect too effective at doing their job. This prevents the rings from bedding in properly and maintaining a good seal against the cylinders which then causes the cylinder bores to glaze up and the engine then starts to burn oil which is only reversible with an engine rebuild.
522226
