Monday, Sep 17, 2007 at 13:44
Peter.
I've actually checked early this morning by watching my (+) (-) Ammeter installed in-line between the Aux AGM Storage batteries and the Solar regulator.
It was showing a constant 3.4 Amps was going into the AGM batteries.
The AGM Storage battery Voltage was showing as 13.8 Volts, which is normal.
I had some-one start the engine, after a few 'seconds' the Amps suddenly went back to ZERO.
This iindicates NO
Solar power was going from the Solar Regulator to the AGM Storage batteries, with the engine running.
However the Storage battery Voltage suddenly went 'UP'
- from 13.8v to 14.4v.
I believe I can explain the "few seconds" by saying the Cranking battery was initially recharged by the Alternator.
Then the Rotronics battery Isolator closed to allow the Alternator to put charge direct into the AGM Storage batteries.
Therefore no
Solar Power is charging the Aux battery system when the vehicle is being driven.
ALL power to the Aux battery system is supplied direct from the Alternator.
524148
