Heavy F250
Submitted: Monday, Sep 10, 2007 at 20:29
ThreadID: 49535 Views:2961 Replies:11 FollowUps:9
Hi All
I've just weighed my effie, fully loaded with it's new steel canopy, tinnie, engine etc. Damn close to 5 tonne! Not supprisingly it takes a lot longer to pull up which got me thinking about (greater) brake wear. Has anyone had any experience with this? If so what remedies or upgrades did you (need to) make.
Thx
Reply By: ZukscooterX90 (Qld) - Monday, Sep 10, 2007 at 20:32
John,the simple answer to your Q. is use your GEARS that is what they are for.:0))
Cheers Bob.
AnswerID: 261441
Follow Up By: Member - John S (VIC) - Monday, Sep 10, 2007 at 21:28
Automatic - so not that efficient.
FollowupID: 522813
Follow Up By: Rob from Cairns Offroad Training & Tours - Tuesday, Sep 11, 2007 at 09:03
Gears are for goin' and brakes are for stoppin'
Cheers Rob
FollowupID: 522857
Follow Up By: Bware (Tweed Valley) - Tuesday, Sep 11, 2007 at 09:22
I think it was the hotel in Woodburn, NSW, that had a quote on the wall by one of the locals: "What's cheaper; gears or brakes?" lol
FollowupID: 522859
Follow Up By: Pezza (Bris) - Tuesday, Sep 11, 2007 at 19:23
"Gears are for goin' and brakes are for stoppin' "
Remind me to never let you drive a 68 tonne B-double down the Toowoomba range !
FollowupID: 522975
Follow Up By: Member - Doug T (Qld) - Tuesday, Sep 11, 2007 at 19:34
Pezza
"Gears are for goin' and brakes are for stoppin' "...Yes except I was going to Use Kuranda Range, I hauled a load of crushed cars down there one night, got to the bottom and I could have put my hand on any of the brake drums ....totally cold
FollowupID: 522979
Reply By: Trevor R (QLD) - Monday, Sep 10, 2007 at 20:52
Hi John,
You could always look into exhaust brakes for your beast if you do have premature brake wear. That is one heavy rig to pull up though!!!
Cheers, trevor.
AnswerID: 261445
Follow Up By: Pezza (Bris) - Tuesday, Sep 11, 2007 at 19:26
Damn thing is nearly as heavy as a green GU I know of when the owner has it loaded up for a business trip, lol.
Pezza
FollowupID: 522976
Follow Up By: Trevor R (QLD) - Wednesday, Sep 12, 2007 at 10:26
Yeah hence my practical solution as opposed to my condemnation of overloading a vehicle. Can't have the pot calling the kettle black can we LOL!!!
Cheers old fella.
Trevor.
FollowupID: 523115
Reply By: Crackles - Monday, Sep 10, 2007 at 22:13
Half a tonne over GVM. Best remedy would be to take some weight off ;-)
Our work F trucks are about 200kg over & don't appear to suffer too much from increased pad wear despite some quick drivers & heavy trailers. Its' a shame that a truck of it's size can legally carry less weight than a Rodeo Ute in some models. Your other option is to tow a trailer which is what the Ford 250 is made to do, not carry weight.
Cheers Craig.................
AnswerID: 261456
Reply By: Skippy In The GU - Monday, Sep 10, 2007 at 23:21
I hope you have a light truck licence to drive your effie,
AnswerID: 261462
Reply By: Member - Oldplodder (QLD) - Tuesday, Sep 11, 2007 at 07:56
Go smaller tyres, brakes will be more effecient that way. :o))
AnswerID: 261495
Reply By: Member - Doug T (Qld) - Tuesday, Sep 11, 2007 at 08:42
Begin your slow down earlier, ie when having to stop at Lights,Stop signs,Drivers rely too much on brakes, What I see when driving in cities is drivers that can see a red light but still charge onward like in a race and brake at the last minute, I see drivers on country roads braking for mild corners and think to myself...why did he/she touch the brake and 'm catching up but don't need to brake at the same position, Watch the truckies when they approach a set of lights on red, what you will see is common sense, try and keep it rolling in 2nd so you don't have to come to a complete stop......until some idiot in a car or 4x4 jumps in front and fills the gap, Should have a pre-loaded sling shot in the grill and put a marble through the rear window,
AnswerID: 261503
Follow Up By: Pezza (Bris) - Tuesday, Sep 11, 2007 at 19:28
For once I totally agree with your whole statement Doug, especially the last bit :-)
Pezza
FollowupID: 522978
Reply By: DIO - Tuesday, Sep 11, 2007 at 09:10
Reduce the weight and stick within the manufacturers specifications. You are a disaster waiting to happen.
AnswerID: 261509
Follow Up By: Redback - Tuesday, Sep 11, 2007 at 09:34
Yep way over loaded and should NOT be on the road.
Take it back to the GVM.
Baz.
FollowupID: 522865
Reply By: disco driver - Tuesday, Sep 11, 2007 at 15:00
Hi All,
Just thought of another alternative.............
Sell the F250 and buy a F350, gives you an extra tonne to fill up.
Of course one could always take less stuff (leave SWMBO at home with the kids), that way you only need one change of clothes and heaps more room for essentials, eg - beer and bait. LOL
Disco
AnswerID: 261552
Reply By: Gerhardp1 - Tuesday, Sep 11, 2007 at 15:47
Presumably you have got truck tyres on it which are rated for the excessive load?
Might be worth checking with your insurance to see if you are covered, before you get an expensive surprise when you smash up the rear of someone because the brakes couldn't stop you, or the overloaded tyres blew.
AnswerID: 261562
Reply By: Exploder - Tuesday, Sep 11, 2007 at 18:22
Slotted Rotors
Better Pads
Exhaust Brakes
would be the 3 options i would be looking at, Exhaust brakes are between U.S$455-$1200 depending on the system and manufacture.
AnswerID: 261579
Reply By: Member - DOZER- Tuesday, Sep 11, 2007 at 20:55
Cobber....trailer is the way to go, if someone pulls out on you, it wont matter if they were in the wrong, you will be liable once they weigh the truck. One option open to you is a trip to ARB for some load carrying springs and a gvm upgrade.... and that will be more than a trailer.
AnswerID: 261611
