Lap tops
Submitted: Tuesday, Sep 11, 2007 at 06:54
ThreadID: 49547 Views:3992 Replies:13 FollowUps:50
Hi all just bought a new Toshiba Satellite lap top computer and installed was windows vista.
I down loaded quick books V7 and it doesn't work properly, it wont back up but does every thing else.
I have asked the place were it was purchased the lap top from and they say I will have to buy a newer version of quick books .
Is this true or are they just try to make another sale.
All the best
Eric
Reply By: Mike Harding - Tuesday, Sep 11, 2007 at 07:11
Probably.
Personally I would ditch Vista and install XP.
Mike Harding
AnswerID: 261477
Follow Up By: Mike Harding - Tuesday, Sep 11, 2007 at 07:15
http://www.quicken.com.au/Support/vistaUpdate.aspx
FollowupID: 522839
Follow Up By: Eric from Cape York Connections - Tuesday, Sep 11, 2007 at 07:19
My other computer runs xp and all works fine so it makes me think its vista.
All the best
Eric
FollowupID: 522840
Follow Up By: Member - Doug T (Qld) - Tuesday, Sep 11, 2007 at 10:20
Mike
I said that for me once when I went from W98 SE to XP. You blokes have no patience, and no idea, I been using Vista on my Daughters PC and found it great, as I said in my other post in this section if a program is not compatible you can change the settings.....if you know how
FollowupID: 522875
Follow Up By: Mike Harding - Tuesday, Sep 11, 2007 at 10:28
Actually, Doug, I do have an idea - and, no doubt, a lot more of one in this area than you.
Perhaps you would share with us your professional qualifications and professional experience in the area of computing with particular regard to operating systems?
Mike Harding
FollowupID: 522879
Follow Up By:- Tuesday, Sep 11, 2007 at 10:28
==>You blokes have no patience
Yep, you spot on – to use Vista one needs *A LOT OF* patience. I would ditch it on the spot in favor of XP, or better still W200Pro. FYI I am IT professional (i.e. earn money by program computers) and I am using W2K. It is lighting fast on new hardware and I fail to see even slightest to upgrade to anything else. Perhaps just make Bill richer.
FollowupID: 522880
Follow Up By: Member - Doug T (Qld) - Tuesday, Sep 11, 2007 at 10:41
Mike
I don't give a crap what qualifications you have but if you have them why don't you use them, As for me NO i don't have IT qualifications, I don't work on computers for a living, I can negotiate PCs enough to sort out my own issues and I don't mind giving some hints to others if it will help , Not throw in the towel like you and say "Personally I would ditch Vista and install XP". Where's your super know how Mike. use it instead of going on with all your usual crap and give some useful information to those who need it or press the little red button in the top right corner,
FollowupID: 522883
Follow Up By:- Tuesday, Sep 11, 2007 at 10:52
Doug, biggest problem is no-one *NEED* Vista at all, it is just marketing gimmick to make people pay more money. As far as progress in OS goes it stops in Microsoft case at NT4.0. I am using W2K (instead of NT) for two main reason – USB support and easies of changing settings (NT require rebooting even if you change screen resolution). As far as stability and performance W2K far superior to XP. And Vista require monster computer to run smoothly – 1G of RAM is just barely enough. Thus one need to spend even more money to keep “up to date”. And what to gain instead? Productivity? Nope. Stability? No way! Just flashy (or should I say flUshy :-) ) looks. And for this pay lots of money for hardware and software? Not enough justification for me – I need a tool, fast and stable one.
Cheers.
FollowupID: 522885
Follow Up By: Mike Harding - Tuesday, Sep 11, 2007 at 11:08
Doug: when posting to this forum in regard to areas of technology you would be well advised to follow the advice of George Eliot:
"Blessed is the man, who having nothing to say, abstains from giving wordy evidence of the fact."
George Eliot
Mike Harding
FollowupID: 522887
Follow Up By: Member - Doug T (Qld) - Tuesday, Sep 11, 2007 at 11:48
I could'nt give a Rats ar$e about some has been called George Eliot
FollowupID: 522892
Follow Up By: Eric from Cape York Connections - Tuesday, Sep 11, 2007 at 11:49
Come on fellows settle.
The advice It sounds like is to dump vista and reload xp on the new lap top.
QB runs on the lap top the only thing I cant do is back up to any thing not even the C drive.
I personally don't see any difference with vista other it wont let QB back up.
I can back up on my other computer and that runs xp.
So I feel its a vista issue.
Will xp still run my lap top OK or is this going to be another problem.
Many thanks
Eric
FollowupID: 522893
Follow Up By:- Tuesday, Sep 11, 2007 at 15:14
XP will run on your laptop perfectly fine assuming that you can get drivers for it. Check with manufacture (i.e. look at their website and try to download drivers for XP for your hardware; be aware that some drivers set unavailable in some contry, so check Europe, USA and Singapore sites as well).
FollowupID: 522939
Follow Up By: Waynepd (NSW) - Wednesday, Sep 12, 2007 at 08:18
Hi Eric,
I have Vista on a laptop and from what i gather, if any program has to make changes to a file such as backups etc then that file cannot be in the Program Files folder because it doesn't allow writing to the files in that folder.
I think if you change the location of your backup files to another location outside of the Programs Files folder it might work. I have had no problems using Vista even though i tried to get a laptop with XP on it at first i am happy to use vista now.
Its in the documentation somewhere and i have read it on IT forums.
FollowupID: 523088
Follow Up By: Member - Davoe (Nullagine) - Wednesday, Sep 12, 2007 at 08:57
The thing IT people CANT tell you or understand is that the main thing an IT system needs is useability. If I cant use it it useless and if it takes me too long to work out then its a waste of time.
All the features or updates wont change that fact
FollowupID: 523093
Follow Up By: Flash - Thursday, Sep 13, 2007 at 16:11
DougT.
I would suggest you don't really have a clue.
Eric,
I know so many people with MAJOR hassles with Vista. As usual MS brought it out with so many known problems, and so much "designed in" obsolescence as far as other software is concerned. It's all about the mighty $$$.
XP runs much better and faster than Vista on any computer.
I would definitely ditch Vista and go for XP in preference.
Hooroo
FollowupID: 523352
Reply By: Member - Sam (NSW) - Tuesday, Sep 11, 2007 at 07:39
Surely Quicken have a patch or upgrade for existing users.
I had a similar issue with the antivirus i got with a laptop. It was part of the package (not preloaded), but wasn't Vista compatible. However, i simply downloaded the latest Vista compatible version and was able to install that with the same licence key and all was good.
AnswerID: 261482
Follow Up By: Gerhardp1 - Tuesday, Sep 11, 2007 at 10:03
With QB you have to buy the full upgrade to the new version, unless you pay the support charge which will include new versions.
Nothing for nothing from Accounting package vendors.
FollowupID: 522871
Follow Up By: Member - Sam (NSW) - Tuesday, Sep 11, 2007 at 11:42
Doesn't surprise me. Thats really ordinary.
FollowupID: 522891
Follow Up By: Gerhardp1 - Tuesday, Sep 11, 2007 at 11:52
I don't find it surprising that updates cost money, it's OK by me that if someone does work to make a product operate in conditions that didn't exist previously they should get paid for it.
I assume when you work you expect to get paid.
FollowupID: 522894
Follow Up By: Mike Harding - Tuesday, Sep 11, 2007 at 12:00
How about bug fixes? Should one have to pay to have original design faults fixed?
Mike Harding
FollowupID: 522897
Follow Up By: Gerhardp1 - Tuesday, Sep 11, 2007 at 12:11
No, but not running on Vista is not a bug
FollowupID: 522900
Follow Up By: Member - Sam (NSW) - Tuesday, Sep 11, 2007 at 13:54
I agree with regards to paying for upgrades to new versions. Thats fair enough. But something as major as a new O/S release, especially when it is preloaded (forget the whole option of XP preload as not everyone is offering this), to mind, this is where that little thing known as "good faith" comes into play. Surely it would be to the benefit of both the customer and the company to release a patch or revised version to enable at least the version that was current at the time of Vista's release to install onto vista.
Especially if what some people are saying is true and that programs such as QB have not kept up to speed with changes to their own compatibility with XP and the likes. If they still have some legacy print routines etc, then the ownus is even more so on the company to ensure compatibility for their product and not expect the client to "roll back" for just their application.
Fair enough, not supporting earlier versions, but many companies release such patches/updates in "good faith" CA did that with their Internet Security suite and A/V products and I know of a few other vendors who have done the same.
FollowupID: 522921
Follow Up By: Gerhardp1 - Tuesday, Sep 11, 2007 at 14:12
For CA antivirus, you pay maintenance by renewing your subscription annually. In CA's case, that includes product updates, but not all AV providers do that - a certain Yellow one comes to mind....
If you pay maintenance for QB, you also get the updates included, so I can't see how that is different.
The question of how bad the QB and MYOB programs are technically is really a different argument, and you won't find me touting their excellence on that front. I don't think either of them are very good at all. In fact, QB would not activate on XP if you happened to have IE7 installed. It's not just Vista that gives QB problems.....
FollowupID: 522926
Reply By: Truckster (Vic) - Tuesday, Sep 11, 2007 at 07:42
Personally I dont know any business thats gone Vista - but we have 10 new toshy laptops at work, all came with Vista and Office 07...
They all now have XP and 2003 on them, and users are happily working away as before..
If they are like M$oft, you will have to buy a new version, but I'd look for a helpdesk ph # for Quicken in aussie, or an email address in USA and email their support line for your answer.
AnswerID: 261484
Follow Up By: Eric from Cape York Connections - Tuesday, Sep 11, 2007 at 11:53
Hi truckster I have bought the satellite.
Did you have any issues with the lap top not running the same when xp was installed.
Or is that just a dumb question.
All the best
Eric
FollowupID: 522895
Follow Up By: Truckster (Vic) - Tuesday, Sep 11, 2007 at 12:27
No problems a all.
Tecra A9 here just finished changing to XP - running like clock work. Boots same as the other A9 sittin next to it with Vista (vista about 2 seconds quicker but less apps installed - wow)
My Tecra A8 and all others are smooth sailing :)
Do it you wont regret it.. just create a recovery DVD before you start so if it does bleep itself, you can roll back.
I am sure you will be jhappy with what you know
FollowupID: 522902
Follow Up By: Eric from Cape York Connections - Tuesday, Sep 11, 2007 at 15:58
Thanks truckster a few replies up the person is saying you need new drivers and the like what does it all mean.
The one have got is the this is what its called on the user ifo guide.
Toshiba satellite A200/ satellite Pro a200seires.
Whats it all mean can I get vista off it and put XP on it.
All the best
Eric
FollowupID: 522949
Follow Up By: Truckster (Vic) - Wednesday, Sep 12, 2007 at 09:56
I havent had any problems with drivers on any of the I've done...
But with the way today has been for me being home, who knows, it may it maynot...
As long as you create a recovery CD you can always go back.
FollowupID: 523106
Follow Up By: Flash - Thursday, Sep 13, 2007 at 16:30
Truckster,
I am sick to death of problem after problem with Vista on my laptop.
Stupid Question. How do I get a valid copy of XP to run on it? Do I have to fork out more dough to Mr Gates?
FollowupID: 523357
Follow Up By: Mike Harding - Thursday, Sep 13, 2007 at 17:48
Do you really need it to be valid? You have paid for Vista but will not use it so I cannot see a moral issue with using a pirate copy of XP? I appreciate you may have work issues with pirate s/w.
Mike Harding
FollowupID: 523375
Follow Up By: Truckster (Vic) - Saturday, Sep 15, 2007 at 09:18
Vista License is backwards compatible. you can call M$ and they will give you another license free. I have for all mine so far.
FollowupID: 523707
Reply By: Member - Oldplodder (QLD) - Tuesday, Sep 11, 2007 at 07:43
I am still running my MYOB (competition to quickbooks) on XP.
But MYOB have just released a Vista version so it would run. Imagine QB to be the same.
Bought a laptop a few months ago, but managed to get XP loaded.
If you are running any other programmes, check them out for Vista compatibility too.
Notice Oziexplorer still doesn't list Vista in compatible OSs, but the web site does have a page on Vista issues under support. It makes an interesting point that c:\program files\ is now locked under Vista to read only, even for admin privaliges, so that may be part of your problem. Can you back up to another area of the disk?
Sorry, I am an old DOS user, and have seen so many OSs released by Microsoft, it all becomes "ho hum, looks like Bill has to make some more money".
Oh, by the way, service pack 1 for Vista was released last week too. :o)
Now you have Vista, I would take the time to get QB running on Vista if you can. Might take a few phone calls and web browsing.
Wish you luck.
AnswerID: 261485
Follow Up By: Gerhardp1 - Tuesday, Sep 11, 2007 at 10:05
Vista SP1 has not been released yet.
FollowupID: 522872
Follow Up By: Member - Oldplodder (QLD) - Tuesday, Sep 11, 2007 at 16:08
Got this email from Microsoft on the 5/9.
"Windows Vista SP1 Availability
SP1 will contain changes focused on addressing specific reliability and performance issues we've identified via customer feedback, supporting new types of hardware, and adding support for several emerging standards. SP1 also makes additional improvements to the IT administration experience."
Yes, you are right, beta release of SP1 in the next few weeks.
Correction noted, I didn't follow the lead far enough.
FollowupID: 522950
Reply By: Member - Doug T (Qld) - Tuesday, Sep 11, 2007 at 07:46
Place Cursor on the Desktop Icon, right click it and bring up Properties, click TAB called Compatibillity, tick the square, in the drop down menu select Windows XP. .....APPLY/OK
AnswerID: 261487
Follow Up By: Gerhardp1 - Tuesday, Sep 11, 2007 at 10:06
This doesn't work with QB. The program suite is incompatible with Vista. Turning UAC off doesn't overcome the problem either.
FollowupID: 522873
Reply By: Robin Miller - Tuesday, Sep 11, 2007 at 07:55
I'd also takes Trucksters advice and check Quicken help line Eric.
Usually these problems are worked out fairly quick.
That said I brought a Toshiba laptop on friday to supply with a project I am working on and it was last one available with XP and store said they were having trouble moving it as a result, with everyone wanting the latest.
In my case , don't have time for software gliches.
Disappointing thing I found is that this Toshiba Satellite runs off 19v unlike previous ones I have which could be run directly from car battery.
Also the new laptops don't have the serial comms ports anymore which used to connect to old GPS etc , but you can buy aftermarket ports and I got a couple but they are not as robust as might be expected and are not 100% compatiable so check first if possible.
Robin Miller
AnswerID: 261494
Reply By: Member - Clive G (NZ) - Tuesday, Sep 11, 2007 at 07:57
Eric.
Have had similar problem here. Quick Books V7 and Quicken Personal V7 (I use both) won’t run on Vista, nor will Quick Books 2006 either. It’s to do with where Quicken products keep their data file, Vista won’t allow it. Quicken no longer support V7 so you have to work your way up through 2 or 3 up grades. Tried a dummy run here at work and lots of historical data was lost. So I’ve stuck with XP Pro and will do so till the bitter end.
Regards. Clive G (NZ)
AnswerID: 261496
Follow Up By: Eric from Cape York Connections - Tuesday, Sep 11, 2007 at 11:57
Hi Clive I can run QB V7 on the lap top but cant back it up
Is that what you found or it just wouldn't run.
Many thanks
Eric
FollowupID: 522896
Follow Up By: Member - Clive G (NZ) - Tuesday, Sep 11, 2007 at 14:05
Eric.
Got a new Desk top at work with vista. Tried to load QB v7 and Quicken Personal from their original CDs and they wouldn't install at all. Just brought up error message. Rang Quicken help line and they said no go for vista and no patch as they no longer support V7. Purchased an upgrade to QB2007 and it had copies of earlier verisions on the CD, which you use in stages to up grade from realy old versions. Lost a lot if not all my archive data. Dealer took new machine away and replaced with XP Pro like we run all through here, and lap tops as well. QB7 loaded fine onto new machine then, and it works good. Did a full back up and put it away before I started on any of this.
Clive.
FollowupID: 522925
Reply By: DIO - Tuesday, Sep 11, 2007 at 09:07
Don't listen to all the 'doomsdayers' stick with VISTA. On a new system it will be fine. As you've discovered you can run into some problems with older software, HOWEVER it is possible to sometimes get the OS to recognise such sw and configure it to run. It is an inbuilt feature of VISTA. If you can't find it, check with your suppliers they should be able to go straight to it for you. Good luck.
AnswerID: 261508
Follow Up By: Member - Doug T (Qld) - Tuesday, Sep 11, 2007 at 10:23
Hmmmmm that is one of the most intelligent answers I have seen from you, ...good one
FollowupID: 522877
Follow Up By: Truckster (Vic) - Tuesday, Sep 11, 2007 at 14:21
but not always... and in this case, it doesnt work. so optionsa re to dishout bux on new program when old one works fine and that will do nothing else but to work on vista, or just install XP..
FollowupID: 522932
Follow Up By: Mike Harding - Tuesday, Sep 11, 2007 at 20:49
But isn't Vista newer? So it must be better? And doesn't it have Digital Rights Management which mean the record companies will be able to maximise their profits? And isn't it configured to delete software it doesn't like from your hard drive?
Sounds like a "must buy" to me.
Mike Harding
PS. What does it do which XP doesn't? Security? What a hoot :)
FollowupID: 523013
Follow Up By: Flash - Thursday, Sep 13, 2007 at 16:26
DIO
I know of a huge number of people who've had major dramas with Vista- including me.
Basically a lot of hard work and time and money, to get a "pretty" system up and running, which runs so much worse than XP.
What's the point unless you like donating your hard earned dollars to "poor" old Bill Gates.
Hooroo
FollowupID: 523355
Reply By: Gerhardp1 - Tuesday, Sep 11, 2007 at 10:01
Eric, QB has only recently released the Vista compatible version. If you have everything working except Backup, you can easily back up your data file manually. I am assuming you use a CD/dvd, external drive, or similar. Do not use a Floppy Disk to back up anything under any circumstances - you will surely lose the data.
The older versions won't run, one of the major problems is the change in the print subsytem of Vista. QB installs its own PDF creator so you can send PDF invoices, etc, and this part does not work. Very few printer drivers were carried over into Vista, but Vista comes with inbuilt ones for most - even my Brother MFC 620CN printer/Fax works fine with Vista supplied drivers.
For the record, QB and MYOB have never been truly Windows compatible - QB came from DOS and MYOB came from Apple. It was only the ability of Windows to handle sub-standard third party applications that allowed them to be used at all.
AnswerID: 261519
Follow Up By: Eric from Cape York Connections - Tuesday, Sep 11, 2007 at 12:09
Thanks for the reply how do you back up manually.
As said above all seems to work other than back up It wont let it back up any were on the computer.
Do I have to buy an external drive I am not sure what you are telling me.
All the best
Eric
FollowupID: 522899
Follow Up By: Gerhardp1 - Tuesday, Sep 11, 2007 at 12:28
Find the location of your *.QBW file, and copy it to a CD, USB stick, or external hard drive. It's most likely in C:\Program Files\Intuit\Quickbooks\datafile.
Backing up the file onto the same computer hard drive is next to useless - if your hard drive dies or the laptop gets stolen, your backup can't be accessed.
Grab yourself an external hard drive, or even a 4Gb USB drive and copy tour documents and files to that, and keep in a different location.
FollowupID: 522903
Follow Up By: Eric from Cape York Connections - Tuesday, Sep 11, 2007 at 12:33
I have tried backing up to a usb but it wouldnt do that either.
It goes throught the motions but when completed says back up was NOT sucsesfull.
Mnay thanks
Eric
FollowupID: 522904
Follow Up By: Gerhardp1 - Tuesday, Sep 11, 2007 at 12:39
Backup from within Quickbooks may fail, but COPY the file as I described will not fail (make sure Quickbooks is not using the file)
FollowupID: 522905
Reply By: TerraFirma - Tuesday, Sep 11, 2007 at 15:19
Unfortunately true, Vista is causing some problems. You have 2 choices..
1. Embrace Vista now and get new Quickbooks and move on.
2. Wipe Vista and spend hours reinstalling Windows XP and your Toshiba drivers , not much fun.
It's a hard one but given Vista is the future I would take the pain now and get it over with, a lot easier and Quickbooks should have an upgrade price.
AnswerID: 261556
AnswerID: 261557
Follow Up By: Mike - Tuesday, Sep 11, 2007 at 19:05
For what its worth, I have xp on my Toshiba laptop all my installed programmes work fine, I purchased a new PC for home with Vista installed, had trouble with some of my programmes working, took it to the computer shop where I purchased it and they also had trouble getting them to work, so they loaded XP for me and now every thing works fine.............BUT sooner or later we will have to upgrade to Vista as they won't be doing upgrades liked they stopped doing them for W98se............And you do need at least 1GB of memory to make Vista work properly, I know that you can still use 512kb but 1Gb is what is recommended.
FollowupID: 522974
Follow Up By: Eric from Cape York Connections - Tuesday, Sep 11, 2007 at 20:37
Mike what model Toshiba satellite have you got.
All the best
Eric
FollowupID: 523000
Follow Up By: Mike - Wednesday, Sep 12, 2007 at 03:04
I have the Toshiba "Tecra" a great laptop
FollowupID: 523069
Follow Up By: Truckster (Vic) - Wednesday, Sep 12, 2007 at 10:13
Actually if you wait 2yrs, the replacement for Vista will be out according to Uncle Gates...
FollowupID: 523113
Reply By: Member - Matt & Julie (VIC) - Tuesday, Sep 11, 2007 at 19:41
Hi Eric
We purchased a Toshiba Satellite 200 about 5 weeks ago wanted
to put oziexplorer on Vista wouldn't accept it took it back to
where we purchased it to see if we could put XP on they rang
Toshiba and Toshiba said that it wouldn't accept XP so we had
decided to change it for an Asus that would accept XP we had
no trouble with the computer over the last 3 weeks on our
trip across the SD, charged the computer on our inverter everything worked perfectly.
Matt & Julie
AnswerID: 261589
Follow Up By: Eric from Cape York Connections - Tuesday, Sep 11, 2007 at 20:40
Did the store you bought it from exchange it for you.
All the best
Eric
FollowupID: 523005
Reply By: TerraFirma - Wednesday, Sep 12, 2007 at 10:19
The manufacturers are not shipping with Windows XP anymore, Vista is it. Take the pain now and move on...
You'll have to upgrade eventually , believe me, so may as well do it now..!
Cold hard facts.. I'm in the industry..
AnswerID: 261681
Follow Up By: Flash - Thursday, Sep 13, 2007 at 16:34
Vista Sucks!
My latest laptop with Vista has caused a massive amount of grief and wasted time.
My next computer will be an Apple!
FollowupID: 523359
Follow Up By: TerraFirma - Thursday, Sep 13, 2007 at 16:36
Yes Vista sucks, buy an Apple and then you'll be posting it sucks too eventually..!
FollowupID: 523361
Follow Up By: disco1942 - Thursday, Sep 13, 2007 at 20:38
There is nothing to say you have to use every version of M$ Windows. My upgrade progression was DR DOS, Win 3.11, Win 98se, and finally XP. As you can see I have skipped a few versions. If I can get my BigPond wireless modem to work on Linux then Windows gets the flick.
FollowupID: 523411
Follow Up By: Truckster (Vic) - Saturday, Sep 15, 2007 at 09:21
Valid point = Vista is just a pretty pretty...
FollowupID: 523708
