Fullriver agm battery terminal help
Submitted: Thursday, Sep 13, 2007 at 10:14
ThreadID: 49615 Views:2537 Replies:5 FollowUps:1
HI All
I have a 120amp fullriver agm in my camper that I am very happy with. It has the screw in type terminal not the regular auto style poles that sit up for terminals to be attached to.
I want to be able to connect a disconnect style terminal to it... so my charger is not always connected.
Any ideas?
Reply By: DIO - Thursday, Sep 13, 2007 at 10:48
Have you thought about using a suitable alligator type clip. Easye to put on and remove.
AnswerID: 261861
Reply By: Ingtar - Thursday, Sep 13, 2007 at 11:05
Wire in an anderson plug?
Sturdy connection, protected from shorts, easy to use?
AnswerID: 261863
Follow Up By: TerraFirma - Thursday, Sep 13, 2007 at 12:14
Smart choice..
FollowupID: 523313
Reply By: Sacred Cow - Thursday, Sep 13, 2007 at 12:43
BCF sell a New Zealand made 200 A switch which should be suitable for your application.
Glenn
AnswerID: 261879
Reply By: garryk - Thursday, Sep 13, 2007 at 13:23
If you can find a scrap AGM genuine Oddessy Battery ( the orange metal case made in USA orignal AGM )
they have a bolt on conventional automotive style post its made of brass
Just made sure the contact faces are perfectly clean
I had the same wish and discovered that only this morning
Its either that or wire thru a battery isolater
Garry
AnswerID: 261887
Reply By: Member - Mottleman (NSW) - Thursday, Sep 13, 2007 at 13:50
Thanks for all the ideas... very useful.
For the specific use I have the Anderson plug will do the job beautifully and allow me to take the charger onto my boat.
AnswerID: 261895
