cleaning caravan
Submitted: Friday, Sep 14, 2007 at 14:46
ThreadID: 49654 Views:2595 Replies:4 FollowUps:2
cleaninghow can i get diesel smoke grime off side of van
Reply By: Gerhardp1 - Friday, Sep 14, 2007 at 14:58
Something like sugar soap might do it - test a small area first. Otherwise washing down with kerosene or turps (use the low odour ones) followed by detergents should do the trick.
AnswerID: 262068
Reply By: Therifleman - Friday, Sep 14, 2007 at 15:16
Same problem recently in Darwin.Tried Kero.,Turps.,"Spray & Wipe".Just so-so.I then used CT 18 car wash & it did a better job than all the others with a lot less effort.
I might add,mix the solution in your bucket stronger than normal & use a soft broom.
This works for me.
AnswerID: 262070
Follow Up By: disco driver - Friday, Sep 14, 2007 at 16:32
Truck wash, similar to CT18, and a soft broom followed by a good hose off with fresh water. (Don't pinch SWMBO's good broom, go and buy one for vehicle washing only).
Might be a problem, using the hose in some areas, but a good sponge and plenty of clean water from a bucket will work just as well.
Disco
FollowupID: 523565
Reply By: Member - Dunworkin (WA) - Friday, Sep 14, 2007 at 15:23
We use a polish called 'Mothers California Gold Sealer and Glaze' phase two, it takes off all marks and leaves a good shine. We got it from our local Auto 1 store but should be able to get it from any auto parts shop.
D
Simba, our much missed baby.
AnswerID: 262074
Reply By: Member - RnR (NSW) - Friday, Sep 14, 2007 at 15:24
Nappisan also works a treat. You can dilute if you need to
RnR
AnswerID: 262075
Follow Up By: Member - Peter R (QLD) - Friday, Sep 14, 2007 at 17:28
I found the Counteract Pre Cleaner works well
Pre Cleaner to get off heavy grime
Pedro
FollowupID: 523579
