2001 GU 3.0 Patrol - Rattle at Idle
Submitted: Friday, Sep 14, 2007 at 21:40
flyboy
Can anyone help me? I have a 2001 GU Patrol, 3.0 Litre, Manual, 115000 Klms. Over the last 1000klms or so it has developed an intermittent "clanging" type rattle at idle (will dissippear just above the specified idle speed of 750 rpm). It sometime starts as a knocking sound. No sound evident whilst in gear and mobile. HAve checked as much as visibly possible but nothing obvious. Car was in at Nissan today having another problem fixed (primer pump) but of course vehicle would not exhibit the fault whilst with them. Any advice would be greatly appreciated.
Many Thanks
Reply By: patrolbloke - Friday, Sep 14, 2007 at 21:46
flyboy ,chec k drive blt tesion device
Mine flogged it self to death at 100000 k about 300/400 to renew hope this helps
262144
Follow Up By: flyboy - Friday, Sep 14, 2007 at 21:51
Patrolbloke,
Thanks for your advice...Did you have the distinctive clanging type sound....This has got me buggered!!!
523664
Follow Up By: patrolbloke - Friday, Sep 14, 2007 at 22:11
flyboy,it seemed to come from the fan area intermittently. Nissan repairer in Kunnunarra said its quite common They even keep them as a shelf item
523669
Follow Up By: Member - Glenn D (NSW) - Friday, Sep 14, 2007 at 22:24
Hows it going Bloke ,
I had this problem and on
mine it made more like a squeal cause the bearing in the pulley was shot .
Hope this helps .
Glenn.
523673
Reply By: Shaker - Friday, Sep 14, 2007 at 21:51
Input shaft?
262145
Reply By: obee - Friday, Sep 14, 2007 at 21:57
With clutch engaged or not? I have had noises from gear box in past vehicle. Next time you get the noise you need a big scredriver against you rear and put the other end on head, block etc. Stethoscope would be better.
Owen
262146
Follow Up By: Member - Stephen M (NSW) - Friday, Sep 14, 2007 at 22:21
Hi Owen not sure how the screwdriver will go planted on his rear LOL. Regards Steve M
523672
Reply By: Hairy (NT) - Friday, Sep 14, 2007 at 23:11
Gday,
Direct the post at Handy, If anyone knows about rattly Nissans he would.
Bwhahahaaaaa
262161
Reply By: Phil100 - Saturday, Sep 15, 2007 at 12:15
Check the serpintine drive belt tensioner, the bushes flog out and you hear aslapping sound at idle, worse in wet weather.
262235
Reply By: flyboy - Saturday, Sep 15, 2007 at 23:38
thanks all who responded...A little more on the story...Car was put into Nissan Service last Friday to get the problem looked at, as
well as another problem - sluggish, missing at low rpm, poorer
fuel consumption, and engine fault indicator light coming on intermittently (I checked for
water in filter - nil)
After 3 hours of diagnostics, they tell me they discovered there is air in the
fuel line which is causing the engine problem. A new primer pump is required and is on order. Co-incidently, performance has quite worse in the last few days, engine light on more often, but rattle has dissipeared. Could it be something to do with engine problem? Nissan tell me the performance problem is a snowball effect, lack of
fuel reaching the engine, computer says more boost please, then the whole thing just goes downhill from there. I'm no mechanic, so i'm a bit oblivious to it all!! is it normal for a service centre to charge for their "Diagnostic Time", 3 hours in this case? Thanks again everyone for your comments.
262357
Reply By: Muzzgit [WA] - Sunday, Sep 16, 2007 at 00:55
What the buggers don't tell you is they are only guessing and you're paying for it!!!
My first thaught, having a 3.0 Patrol myself, is ask for a new MAFS, now, regardless of what they say.
MANY MANY, MANY 3.0 patrol owners have had similar problems to yours and most have been a faulty MAFS (mass air flow sensor)
262372
Follow Up By: flyboy - Sunday, Sep 16, 2007 at 15:30
Thanks Muzz,
How many figures are after the dollar
sign for a MFAS????
I can only imagine...4wd's - Generally everything costs at least a three digit number or more after the $
sign!!
Cheers & Thanks!!
523963
Follow Up By: Muzzgit [WA] - Sunday, Sep 16, 2007 at 16:44
The MAFS should be around $250. Don't let them talk you into the whole thing, plastic pipes and intake duct (one
young bloke tried that on me) it will cost heaps more.
Just the MAFS! You need tamper proof allen keys to change it over, and I will bet a carton most of your problems will be fixed.
I have replaced
mine twice (just clocked 140,000klm) and I recon she's due for a new one soon.
523979
Follow Up By: flyboy - Sunday, Sep 16, 2007 at 19:13
Tnx Muz,
I'll post the outcome here when I get it back.
524018
