Brake Problems - Pajero
Submitted: Sunday, Sep 23, 2007 at 22:01
alcokev
Hi All,
I had problems on my last trip away, when i was going up hills and couldn't go any further the car rolls back so i apply the brakes and the pedal doesn't compress, so im rolling backwards and bleep ting myself. but i comes back after a few seconds. it works fine on the road.... ?? 1995 pajero 3L V6
kevin
Reply By: Member - desray (WA) - Sunday, Sep 23, 2007 at 23:41
You say the Pedal doesn't compress, does this mean it went to the floor and came good with a few pumps on the pedal. Some of the Pajero,s had a problem with the front brake pads moving away from the disc and had to pump them a few times to get them back. They had a anti rattle spring or somthing on the pads that was left out when the pads were changed ? Somthing to look at ?
263670
Reply By: alcokev - Monday, Sep 24, 2007 at 00:44
no the pedal did not compress, just as if the engine wasn't running, but it was. pretty scary..... like it was locked.
263675
Reply By: Member - Alastair D (NSW) - Monday, Sep 24, 2007 at 09:30
This rings a bell from many years ago, but not on a Pajero. The vacuum hose to the brake unit had gone soft and tended to collapse in on itself - symptoms just like you say. Have just sold my 3L Pajero so I can't have a look and see if it is likely. Worth a look when the engine is running a see if the hose looks round all the way.
263703
Reply By: Member - Vince B (NSW) - Monday, Sep 24, 2007 at 13:41
Hi Kevin.
Try the pajero 4wd club
forum(series 2 section).
I have found .
Vince this
forum to be a good source of info regarding pajero's
263725
Follow Up By: Member - Vince B (NSW) - Monday, Sep 24, 2007 at 13:43
Hi Kevin.
Lets try this again.
forum.(series 2 section).
I have found this
forum to be a good source of info regarding pajero's.
Vince
525330
