water tanks
have recently put a 60 lt tank on camper trailer with a 12 vt pump, much more posher than a pump tap. wanting to know should i fill up water tank after every trip or is it OK to be empty and fill it up before i go away next time. is there anything i should put in the tank to stop any bateria??
Reply By: obee - Thursday, Sep 27, 2007 at 18:57
The water board puts chlorine in the water and it disappears over time. Put a good slug of the stuff in now and empty the tank when next you go out. Household bleach is a weak blend of chlorine and will do the trick.
(oh yeah dont forget to put fresh water back in.
Actually the water board wants you to run your taps when you get home from a period away so chlorinated water replaces the old stuff in the pipes. Dunno if anyone ever does it.
Owen
AnswerID: 264227
Follow Up By: RedGibber - Thursday, Sep 27, 2007 at 19:40
Owen,
Which water board?? That is, which state??
Andy
FollowupID: 525971
Follow Up By: obee - Friday, Sep 28, 2007 at 20:26
The government keeps changing the names and privatising and I cant be stuffed looking up what they call it now. Water dept probably in WA. I read the advice about running the taps a long time ago but I can see how they might want to cover themselves if the household pipes got a bit whiffy.
Owen
FollowupID: 526033
Reply By: lifeisgood - Thursday, Sep 27, 2007 at 19:57
I dont bother too much anymore with the purity of our van tanks.
We carry easy to clean 2o litre plastic tanks for good water and top up the van tank before leaving or en-route with whatever reasonable water we can get. Some areas its not that flash. eg bore water. We only use the van tank for washing up etc or boil it if drinking it (coffee ) and fresh is getting low.
you also have a little insurance in case you rip the hoses off your van tank and lose the precious fluid. (particularily if remote camping and not near a good stream)
AnswerID: 264242
Reply By: Wizard1 - Friday, Sep 28, 2007 at 11:49
When we get home I use the left over water to wash the van down by attaching a hose to the drain outlet and a Gerni.
If left in too long it will taint with the flavour of plastic so I may as well use it up. Otherwise I would only drain it onto the ground.
AnswerID: 264262
