O/T Help with finding fuel filter Ford Laser 1993
Submitted: Saturday, Sep 29, 2007 at 13:59
ThreadID: 50122 Views:7667 Replies:5 FollowUps:4
Can anyone tell me where the bloody hell the fuel filter is in a 1993 Ford Laser - 16 valve carby engine. Bu**ered if'n I can find it.
Thanks in advance
Pete
Reply By: Shaker - Saturday, Sep 29, 2007 at 14:00
Have you looked at the fuel tank?
AnswerID: 264366
Follow Up By: Patrol22 - Saturday, Sep 29, 2007 at 14:04
Nope but will do
FollowupID: 526101
Reply By: rescue134 - Saturday, Sep 29, 2007 at 14:01
have a look on the left hand side near the strut piller
AnswerID: 264367
Thanks rescue134 - can you be a bit more specific with that location - I'm a bit of a numpty with such terms.
FollowupID: 526100
Reply By: herkman - Saturday, Sep 29, 2007 at 15:47
I would start by lifting out the rear seat base.
If yoiu see a removable inspection plate. perhaps held by screws, that is the spot.
You will need most likely to remove the fuel pump from the tank.
Make sure you have the battery disconnected, you do not need any sparks there.
I would start by purchasing a replacement filter, you do not want to go in there twice.
Col
AnswerID: 264373
Follow Up By: Patrol22 - Saturday, Sep 29, 2007 at 15:50
Thanks Col. Sounds a bit daunting for me.....I was hoping that there would be an in line filter somewhere easier to get at.
FollowupID: 526105
Reply By: rescue134 - Saturday, Sep 29, 2007 at 16:36
in the engine bay on the passenger side of the spring / shocker post.
it is held in by a spring clip that you can pull out to remove,
this is a carby model, if not there it will be on the frie wall where the passengers feet would be.
hope this would help
kev
AnswerID: 264379
Follow Up By: Patrol22 - Saturday, Sep 29, 2007 at 16:55
Thanks Kev....that be it held in by a spring clip...just doesn't look like the usual in line filter.
Thanks again.
Pete
FollowupID: 526112
Reply By: Gerhardp1 - Sunday, Sep 30, 2007 at 10:36
If it's anything like the filter on my daughter's Mazda 121, it will be a biggish black filter on the passenger side strut, under the bonnet.Fuel inlet is at the bottom, outlet at the top, where the pipe is likely to have a 90 degree bend for a straight run to the carby.
The buggers are not cheap, either!
AnswerID: 264447
