Strap - Snatch or Tow - Who Knows???
Submitted: Monday, Oct 01, 2007 at 09:30
Member - Alex K (NSW)
Hi All,
I was recently given a recovery strap, it's white, 9m long, 50mm wide, 5mm thick, and has no markings or break load limits.
Before using it for the wrong application, how could I work out if it's a snatch strap or winch ext strap?
Alex
Reply By: Wayne (NSW) - Monday, Oct 01, 2007 at 10:30
Alex,
A strap with no rating is worse than not having a strap at all.
It was given to you, so it has cost you nothing up until now and if it does break during a recovery, who knows what it will cost.
A rated snatch strap is not that expensive in the 4WD world of recovery items.
Cut the eyes and then cut the strap into small lengths and buy yourself the right gear.
Wayne
264549
Follow Up By: Rosco - Qld - Monday, Oct 01, 2007 at 11:09
Or alternatively, keep it merely as a tow rope for onroad applications.
526319
Reply By: Robin Miller - Monday, Oct 01, 2007 at 12:42
Hi Alex
Just hook it up to a tree or something and get it tight then see if you can stretch it with the car, if its a snatch it will stretch 200-300mm.
Snatch straps are generally heavier and thicker with a more open weave whereas extension strap looks more like a heavy
seat belt
Robin Miller
264563
Reply By: Member - Andrew (QLD) - Monday, Oct 01, 2007 at 14:02
If in doubt, chuck it out.
Andrew
264568
Reply By: Brian (VIC) - Tuesday, Oct 02, 2007 at 22:25
Should be good for re-stringing that old
camp chair...
264796
