Canoeing the Snowy River
Submitted: Monday, Oct 01, 2007 at 16:43
ThreadID: 50168 Views:8988 Replies:11 FollowUps:6
I’m thinking of spending a week or so doing a canoe trip down the Snowy from the NSW border to Jacksons Crossing or beyond and would appreciate input from anyone who has done this or similar trips, the distance is about 80km. Keep in mind I know nothing about canoes :) Would it be better use a small inflatable raft?
This is pretty tough and remote country some distance from any roads with only a couple of possible exit points if I get into strife – it’s a definite EPIRB trip, I’ll probably upgrade my VHF EPIRB to a UHF one for this trip. I’ll be doing the trip solo probably without any comms gear but I am well experienced in remote area travel.
All advice appreciated.
Mike Harding
mike_harding@fastmail.fm
Reply By: Member - JohnR (Vic)&Moses - Monday, Oct 01, 2007 at 18:18
Mike, there are plenty of books on river sections. I know McKillops Bridge down to the confluence of the Buchan and that was lovely over three days.
Best to train in what ever you are to paddle and don't do it alone. I know you will probably ignore that but that is where trouble usually ocurrs. Best to do a trip like that with company. I am not sure what the river level is, you never know it could be more of a bush walk though. Have a look at the River Heights data and refer to the advice book you get to judge.
I much prefer a plastic kayak and NOT the blow up type as they are dreadful to try to control
AnswerID: 264589
Follow Up By: Member - JohnR (Vic)&Moses - Monday, Oct 01, 2007 at 18:44
Should have added, a strong two person raft isn't bad either for a relatively inexperienced paddler. 20 litre barrels with screw tops then for your dry storage. Kayak dry storage tends to be more specialised. Still have a couple of those bags and good for storing wet gear.
FollowupID: 526370
Reply By: Member - Kim M (VIC) - Monday, Oct 01, 2007 at 19:27
Hi Mike
I haven't kayak the Snowy for many years, and never done the section north of Mckillops Bridge.
What does bother me a bit however, is the statement that you have no experience canoeing, (and intending to do it by yourself). I certainty wouldn't recommend it without some form of training.
If you like, I can give you contact numbers within the Victorian Canoe Association to speak to.
Apart from gaining experience in using a kayak, canoe or raft, they will also teach you about water dynamics which is equally important. For instance, if you can't recognise a strong "Eddy Fence" it's likely that you'll part company with the boat.
Somewhere around the house I have an excellent book on this subject that you can have a lend of.
Don't use a white water kayak because a number of things will happen. You'll spend most of the day going around in circles, and a grade 3 rapid will almost certainly introduce you to a fish view of the river.
If you select a canoe, be aware that all steering is done from the back, not the middle or front of the boat.
Finally, the Snowy can be a treacherous river after rain (fed by numerous tributaries) and can result in a significant rise in water levels. Even in a drought this could happen.
The other respondents have also given good advice re storage protection etc
If you want to know more, give me a ring and we'll discuss it.
Kim
AnswerID: 264599
Reply By: Robin Miller - Monday, Oct 01, 2007 at 20:35
Not a lot of experience here on that Mike , but from the bits I have done a small inflatible has been easiest to handle and live with but not the fastest.
Pretty well always carry a small 2 man (coleman) unit in car these days , but these aren't tough enough for that trip and I remember ripping one from end to end on an overgrowing blackberry bush, sinking in about 10 seconds.
The better units are really tough these days and low water levels I have experienced there have meant a bit of pulling the boat over rocky sections.
Robin Miller
AnswerID: 264606
Reply By: madfisher - Monday, Oct 01, 2007 at 21:01
Just got back from a canoe trip down thje Abercrombie river using a 4.88m canadian and 3.7 Kayak. We use the canadian to lug all the gear and play safe with it and use the kayak for a bit of fun.
DO NOT go buy yourself even if you are very experienced, I believe this is a wld river , have read about it buy not experienced it myself. You have been given good advice Mike take it,
Dont give up on the idea just get swome experience and take a couple of mates, good luck
Cheers Pete
AnswerID: 264611
Reply By: Member - Willie , Epping .Syd. - Monday, Oct 01, 2007 at 21:04
Mike ,
I always thought you were a fairly smart fella and so I am surprised that you have put forward such a stupid plan .
White water - unknown grades , no experience , crap gear , by yourself - you are having a lend of yourself ( I am being nasty in an effort to get you to see sense ) .
Do some more reading , for your own sake . Speak to some of the people in touring canoe clubs in Victoria for some good advice .
Willie .
AnswerID: 264613
Follow Up By: Member - Kim M (VIC) - Monday, Oct 01, 2007 at 22:49
Willie
Your being a bit tough mate. Everything your saying is true, but allow some latitude.
I'll give you a case in point. Bear in mind that I had a lot of experience during this period in my life:
We almost lost my Brother In law on one trip, and a work mate on another. When a fella disappears under water for a long time it's not a pleasant experience.
I'll give you an example of how things can go wrong. Back in the 70's (before the Thompson Dam was build) we put in at Coopers Creek and spend a good part of the day dragging the canoe through low water (Summer).
Things improved a bit after that until we came to a water fall with a cliff directly opposite. The drop was around 8-9ft which we went over, then slammed into the rock. The result was a far bit of damage to the boat which took a few hours to repair and cure.
What we didn't know, was that a major storm front in the upper Thompson catchment area was going to present us with a few issues, and this happened quickly. At the time we were in very steep country and soon realized we could be in trouble.
Eventually we found a small area approximately 30 ft above the water level and used the canoe to sleep under. At some point in the night, I woke up and found the water just below us. The night was as black a soot, but we managed to get up further and tied the canoe and us to a tree.
The interesting thing in talking about this, Is that I have memory of the detail, but can't recall how we got out of the situation.
So much for old farts!
Kim
FollowupID: 526421
Follow Up By: Member - Willie , Epping .Syd. - Tuesday, Oct 02, 2007 at 08:24
Kim ,
I am a white water tourer from way back , and I have been trapped underwater in branches , smashed kayaks etc , so I know the dangers .
Mike knows lots about gold fossicking , and hopefully he will learn lots about white water canoeing before he takes this on. I don't think I am being tough on him , I am trying to make him see the facts ,which seem to have been submerged in his ideals of a "grand adventure".
It seems that the Snowy can vary between a constant portage to a raging torrent - depending on rain .
Willie
FollowupID: 526439
Reply By: Tony MD - Monday, Oct 01, 2007 at 21:28
Mike, I have spent many a Christmas at Jacksons Crossing. From memory, the usual finish point is at Balley HooleySnowy River NP .pdf file.
You will need water! One year of low water flow we picked up a group that had been walking the river & pulling their raft for a couple of days & were out of provisions.
They were the only people that we saw that year - I think 1999 or 2001? One bloke & 3 really cute young laddies - leave it to your imagination :-) Snowy River NP .pdf file
AnswerID: 264622
Follow Up By: Tony MD - Monday, Oct 01, 2007 at 21:29
I was wondering where the URL link disappeared to the first time!!
FollowupID: 526395
Follow Up By: Tony MD - Monday, Oct 01, 2007 at 21:33
Should have also done a spell check - read ladies. Should finish work & put this thing away!!!
FollowupID: 526398
Reply By: Member - Royce- Tuesday, Oct 02, 2007 at 13:05
Sound like great fun.... if you can find enough water..... I'll come!
AnswerID: 264696
Reply By: Dingo77 - Tuesday, Oct 02, 2007 at 14:54
Mike, I've paddled the Snowy about 20 times. Your expression of interest concerns me.You are an inexperienced person wanting to travel solo and you can only think of upgrading an EPIRB to get you out of trouble. How about something like this instead?
1. Join a TOURING canoe club.
2. Learn the skills of canoeing.
3. Do the trip with other people who have some experience.
4. Leave the solo paddling trips until you are competent. Even experienced paddlers rarely paddle solo. 4 is the accepted safe minimum.
5. So, learn some skills, earn some experience and you will enjoy the trip safely - you could even leave the EPIRB at home.
Peter.
AnswerID: 264717
Reply By: Mike Harding - Tuesday, Oct 02, 2007 at 18:23
Thanks for your responses everyone.
John: I’m about to start searching bookshops and libraries and the raft is attractive if it will stand the conditions – it’s a long walk out of there :)
Kim: perhaps we could have a chat over a beer about it?
Robin: yep, the low water is not attractive, that was one of the things I was hoping to get feedback about.
Madfisher: thanks, sound advice.
Willie, me old mate :) – I hear what you say and I thank you for your concern.
Tony: that low water is an issue – I want to boat the river, not walk it!
Royce: the first one I want to do alone but on the second trip (I’m sure they’ll be one :) it would be my pleasure to accompany you.
Dingo: actually I could think of a few other things too but I knew if I didn’t mention an EPIRB on this forum I’d have 28 people telling me I needed one :)
A few points:
I want to do this trip because I love the Snowy, it feels like a friend, a woman even and just like a woman I don’t wish to explore her with another :) I don’t know but maybe it’s something akin to the connection with the land aboriginals feel?
I am certainly inexperienced with all things boat like but I’m not stupid or suicidal. I have no desire to join a club, do training courses, spend time paddling rivers in groups. I shall spend time gaining some experience but, like everything else I have done in my life, I’ll do it my way (sing Frank! :) and not according to rules set up by others.
Of course; being less than expert in this mode of transport and entering into remote country creates a risk to life and limb – that’s OK with me – I have no dependants any longer, my responsibilities are fulfilled and, indeed, it is only by putting some risk element into out lives can we really remember that we are ALIVE! And I like that feeling :) In some ways I would prefer not to take the EPIRB but that, probably, would be foolish.
About 18 months ago I had lunch with a cousin of my own age who I have known since early childhood but only see every 5 or 10 years, we were chatting about my gold prospecting in remote areas and he said “so if we hear you died in the bush we’ll know it was doing what you loved” and he was dead (sorry :) right – if I die in the bush doing something like this I’ll have died happy and fulfilled – that’ll do me :)
So if you guys with direct experience of this trip would like to offer some practical advice I would be most grateful.
Mike Harding
AnswerID: 264749
Reply By: madfisher - Wednesday, Oct 03, 2007 at 11:16
Mike ,
I have been racking my old brain trying to think were I seen an articile on canoeing the snowy river. It was in (WILD ) magazine a couple of years ago. It was a reprint of a trip done I think in the 50s with a large canadian. I was entralled by the article but not adventrous enough to want to do it. lol
If you can find a current issue in a newsagent, and give them a ring they may help you out with a back issue or a reprint of the article.
I will keep on looking to see if I can find it for you.
They may even pay you to do a story on your trip lol.
Cheers Pete
AnswerID: 264842
Follow Up By: Mike Harding - Wednesday, Oct 03, 2007 at 20:34
Hi Pete
Thanks for that - I'll contact them and see if a reprint is available.
You never know your luck and I can think of many worse ways to earn a living :)
Mike Harding
FollowupID: 526744
Reply By: madfisher - Thursday, Oct 11, 2007 at 21:12
Mike I found it. Issue no 89 jul sept 2003. Our Email address is hanrahanfamily@dodo.com.au
Cheers Pete
AnswerID: 266217
