OT - Minimised window
Submitted: Tuesday, Oct 02, 2007 at 07:30
ThreadID: 50183 Views:2098 Replies:4 FollowUps:6
Off topic but when I open the forum webpage (and any other) in IE it opens minimised !
Any clues how to reset it to open full screen ?
Reply By: DIO - Tuesday, Oct 02, 2007 at 08:48
Have you tried clicking on the 'restore to full screen' button top right corner immediately to the left of the RED X the Close button. That should do it.
AnswerID: 264667
Reply By: ExplorOz Team - David - Tuesday, Oct 02, 2007 at 10:37
Geetee,
To fix this close all open IE browsers. Then open one it should open minimised, then restore it to the size you want and close it using the X. Now it should be fixed and when you open another window it will open to the size you selected.
AnswerID: 264681
Follow Up By: Peter McG (Member, Melbourne) - Tuesday, Oct 02, 2007 at 12:15
Tried that - didn't work. Using IE7
FollowupID: 526480
Follow Up By: Member - GeeTee (NT) - Tuesday, Oct 02, 2007 at 13:18
Thanks David,
Tried that and it didn't work ! !
FollowupID: 526490
Follow Up By: Member - John (Vic) - Tuesday, Oct 02, 2007 at 21:20
Thanks David that DID work for me :-).
FollowupID: 526584
Reply By: CraigB - Tuesday, Oct 02, 2007 at 13:25
Hi GeeTee,
Try positioning your mouse in the diagonal corner and while holding left click on the mouse drag to size required. Once done close window and re-open. It should then open to that size.
CraigB
AnswerID: 264700
Follow Up By: Member - GeeTee (NT) - Tuesday, Oct 02, 2007 at 14:09
Thanks CraigB,
That seems to work. Any idea what causes it to go screwy !
GeeTee
FollowupID: 526503
Follow Up By: CraigB - Tuesday, Oct 02, 2007 at 17:59
GeeTee,
If the window was closed when it was minimised Microsoft programs such as IE, Word etc. will usually remember this and make it the default size when you next open that window.
CraigB
FollowupID: 526540
Follow Up By: TD100 - Tuesday, Oct 02, 2007 at 20:02
absolute legends!!that has anoyed the chit out of me for ages and now fixed cheers Paul
FollowupID: 526571
Reply By: Member - Doug T (Qld) - Tuesday, Oct 09, 2007 at 08:37
GeeTee
Not really OT. When you mean Minimised I take it you mean not full screen, Minimised meand it is basicly hidden by clicking the -- in the top right corner, but if you mean half the screen size then I too have the same with EO and have click the square in the top right corner, ...everytime. I have been searching in the settings but no luck yet.
I have a Wide screen , maybe it's because David's setup is still set for square monitors , because I have a blue unused section each side of the EO panel
Doug
AnswerID: 265693
