Full River Battery Under Bonnet
Submitted: Friday, Oct 05, 2007 at 08:55
Member - greg S (QLD)
To all those who have batteries under their bonnet, how many of you have a full river AGM? I have a spare one and am wondering if anyone has the same battery under their bonnet and if the heat from the engine is going to adversely affect it? Best ask before doing it, so any feedback would be greatly appreciated.
Greg S
Reply By: Axel [ the real one ] - Friday, Oct 05, 2007 at 09:08
80 amp Fullriver AGM as starter and 80 amp Fullriver Agm as aux under bonnet , 80 series turbo diesel auto , no problem . in said vehicle for last 3 yrs , same batts under bonnet in previous vehicle for 2.5 yrs , so batts now 5.5 yrs old ,,
265126
Follow Up By: Davo_60 (ACT) - Friday, Oct 05, 2007 at 16:38
Just wondering if the starting battery is different to the normal fullriver, or are they fine to use as either starting or aux?
Dave
527089
Follow Up By: Axel [ the real one ] - Friday, Oct 05, 2007 at 18:51
Davo-60 ,, both of my batts are Fullriver 80amp AGM HGL , the HGL is not a dedicated deep cycle battery but a hybrid that sits inbetween with the benefits of a deep cycle and the recharge and "grunt" [cca] of a starting battery ,,
527106
Follow Up By: Davo_60 (ACT) - Friday, Oct 05, 2007 at 19:17
Thanks Axel, might look into that next time, have a fullriver AGM as an Aux and that has worked
well so far.
Dave
527112
Reply By: Redback - Friday, Oct 05, 2007 at 09:24
60AH Fullriver AGM right next to the Turbo, it has a heat shield to protect it from direct heat, just over 12mths with no probs, unlike the lead acid i had in there before it.
Baz.
265132
Follow Up By: Member - Bucky (VIC) - Saturday, Oct 06, 2007 at 07:00
Must eventually put a heat shield on my 2nd battery on the Navara, similar turbo heating problem, boiled her a bit when travelling up in
the desert last year ( 3 times )
Still hanging in there, 2 1/2 years old now and had one seriously hard life,,,,, will do the right thing eventually ,,,
But ill get another one of those batterys, tough as hell !,,,,
Bucky
527179
Reply By: Member - RnR (NSW) - Friday, Oct 05, 2007 at 10:02
Ditto with the fullriver under the bonnet without any problems.
RnR
265139
Reply By: ExplorOz Team - David - Friday, Oct 05, 2007 at 10:26
100AH Full River AGM - Works a treat.
265143
Reply By: Gerhardp1 - Friday, Oct 05, 2007 at 10:52
100ah, 1000cca AGM battery under bonnet for 18 months, V6 Jackaroo, no problems.
265153
265154
Reply By: Member - Mark E (VIC) - Friday, Oct 05, 2007 at 11:14
Just transferred the 120AH Fullriver from the old Landrover to the new(er) Toyota. Was in the LR for 2.5 years and still like new as far as I can see. Also just bought another for the camper... very happy with them.
Mark
265157
Reply By: Member - greg S (QLD) - Friday, Oct 05, 2007 at 14:49
Sincere thanks to all who answered. I will now try to fit the fullriver into the tray. Looks like it might need a heat shield though, as it is going into an 07 Patrol and it is near the turbo.
It seems that they survive pretty
well under the bonnet, which is good as I didn't really want to buy another battery.
Thanks again..
Greg S
265176
Follow Up By: Robin Miller - Friday, Oct 05, 2007 at 16:52
You can be guaranteed that the battery will have a shorter life under the bonnet when exposed to higher temps Greg.
But a typical 30% off several years may not be an issue anyway.
Robin Miller
527090
Follow Up By: Member - greg S (QLD) - Friday, Oct 05, 2007 at 20:00
Robin,
Thanks for the heads up. I will keep an eye on it to see how it goes.
I also made a shield for it, and bolted this to the tray. Not too sure if it will do a hell of a lot, but anything is worth a try. It's made of a piece of aluminium plate around 2-3mm thick.
Greg S
527118
Reply By: Member - Mike DID - Saturday, Oct 06, 2007 at 10:40
Check the charging voltage when the engine is hot - it should be less than 13.8 volts.
AGMs are better than other construction types, in just about every way - except for tolerance to overcharging in high temperature.
This is because the electrolyte is not in contact with the case to allow heat to escape quickly - unlike Gel or Wetcell.
265275
