"Cheap" portable fridge from eBay
Submitted: Monday, Oct 08, 2007 at 20:06
ThreadID: 50361 Views:7056 Replies:8 FollowUps:3
Hi, anyone purchased one ofthose or similar from jlkcomputer technology?
Any informed comment will be appreciated.
Reply By: PradOz - Monday, Oct 08, 2007 at 21:17
I don't think I would run the risk with all the food and BEER in something I know nothing about.
After all - nothing is as important as keeping the beer cold!!!!
AnswerID: 265634
Reply By: Jimbo Vic - Monday, Oct 08, 2007 at 21:21
I know nothing of them, however, most fridges run the Danfoss compressor, only the casing varies.
If it has a Danfoss compressor, a 55L fridge at this price is a real bargain.
ATB,
Jim.
AnswerID: 265636
Reply By: Member - Doug T (Qld) - Monday, Oct 08, 2007 at 21:51
Get a decent well known brand , don't waste your money on crap,
AnswerID: 265638
Reply By: Member - andrew B (Kununurra) - Tuesday, Oct 09, 2007 at 07:40
mmmm, $549, rrp $1400. Looks very similar to the ones I've seen in Kmart for about $550.
I would pay up to $300 for a "disposable' one for fitting to a boat, but no more.....and I wouldn't risk a brand name in a boat unless of course its a big one!
I think you could get a factory seconds waeco for not much more.
Cheers Andrew
AnswerID: 265677
Follow Up By: George - Wednesday, Oct 10, 2007 at 11:14
If I could find something like that in Kmart at least I wouldn't worry about warranty.
FollowupID: 527904
Reply By: porl - Tuesday, Oct 09, 2007 at 09:13
It says it:
"or heats to +20'c"
Since when was a Danfoss compressor able to heat as well as freeze? I know our air cons can do this just haven't heard of it in a fridge.
So pretty tricky if it can heat, or more likely the seller knows nothing about the product and used a descriptive combination from other sites (including peltier coolers)
Mind you, I suppose it would heat the inside to at least 20C if you turned it off in 30C ambient heat ...
AnswerID: 265704
Reply By: Red Frog - Vic - Tuesday, Oct 09, 2007 at 12:00
Made in China, has a good Domus compressor, RRP $1400 is bulldust, you can easily get an Engel for that, how about warrany and repairs ? Personally I'd rather buy from someone who has a shop front as it gives me someone to yell at :)
AnswerID: 265740
Reply By: George - Tuesday, Oct 09, 2007 at 20:31
Thanks for all input - I think I will give it a miss...
AnswerID: 265808
Follow Up By: George - Wednesday, Oct 10, 2007 at 11:16
... or not.
Considering the only response from the actual user of this fridge appears to be rather positive.
FollowupID: 527905
Reply By: rod2101 - Tuesday, Oct 09, 2007 at 21:38
I got one and so far it is excellent. It cools down very fast and seems to keep things cold for quite a while when switched off ( good insulation ).
Rod
AnswerID: 265827
Follow Up By: George - Wednesday, Oct 10, 2007 at 11:13
Thanks Rod, maybe I will get one after all...
FollowupID: 527903
