Inline non return valve in W/Screen washer line
Submitted: Tuesday, Oct 09, 2007 at 09:48
Member - Howard T (QLD)
Hi everyone,
Can someone help me by advising me if a non return valve is necessary in a windscreen washer line.
Howard.
Reply By: Philip A - Tuesday, Oct 09, 2007 at 10:22
Well, if you do not have one the fluid all drains back down to the reservoir,and every time you use the washers you will have to pump for quite awhile to get the
water up, with the wiper blades grinding across a dirty screen.
You can get them at any Autobahn or whatever for a couple of dollars.
Regards Philip A
265716
Follow Up By: Member - andrew B (Kununurra) - Wednesday, Oct 10, 2007 at 09:14
Quick tip, (I don't like the wipers comeing on until I have the windscreen nice and wet, don't like the auto system) In both my GU and the work toyota 78, if you flick the washer lever like flashing the headlights, the pump squirts but the wipers don't start.
527880
Follow Up By: Bware (Tweed Valley) - Wednesday, Oct 10, 2007 at 09:35
Andrew, the wife's Kia has the auto system. It seems every time I drive it the
water reservoir is empty which I find out while driving into the sun with a dirty windscreen. Usually have to pull over because the wipers have smeared the dirt all over the windscreen. Then of course there is no container of
water in the car for emergencies etc lol
527884
