bearings for troopy
Submitted: Thursday, Oct 11, 2007 at 08:04
ThreadID: 50443 Views:2283 Replies:6 FollowUps:5
About to spend a year on the road and wish to take some spare bearings just in case. Tired of getting ripped of by Mr Toyota so was thinking of sourcing them through CBC or similar. Car 2004 T/D Troopy.
1. are the front and rear wheel bearings the same?
2.how do you get bearing numbers without pulling your car to bits?
Am also wanting to get a set of spare trunion bearings (i think thats what they are called, replaced them once on a previous vehicle) in case of stearing knuckle failier.
Thanks for your time
Lyndon
Now is the only time you own
Decide now what you will,
Place faith not in tomorrow
Reply By: Outnabout David (SA) - Thursday, Oct 11, 2007 at 08:30
You buy a Toyota presumably because you want the best. To do this you pay a premium but when you want some spares you want to go aftermarket because you want to save money.
Have you actually priced the genuine ones? Most people don't that make a post like this..they just assume and in doing so give a false perception.
Wheel bearing kits I presume are still available genuine in kit or at very subsidized prices from the factory.
Price them and if too expensive then put up a post that says TOYOTA WHEEL BEARINGS $XYZ TOO BLOODY EXPENSIVE WHERE CAN I BUY SOMETHING CHEAPER.
There are a number of parts that are relatively well priced at Toyota these days but we only ever remember the $6 trim clip and assume everything is ridiculous.
AnswerID: 266051
Follow Up By: Robnicko - Thursday, Oct 11, 2007 at 08:36
David,
I asked Toyota in Melbourne for a price on wheel bearings for my 80 series (1996) and they said Toyota do not supply them which I thought of as odd because you can get everything else.
Any aftermarket bearing made in Japan is good in my opinion.
Rob
FollowupID: 528098
Follow Up By: Outnabout David (SA) - Thursday, Oct 11, 2007 at 09:03
Well the parts person you spoke to had no idea what you were talking about. You sure you didn't talk to the cleaner?
FollowupID: 528108
Follow Up By: Robnicko - Thursday, Oct 11, 2007 at 09:07
only passing on what Melb City Toyota said.
the cleaner said go to kmart
FollowupID: 528111
Reply By: Outnabout David (SA) - Thursday, Oct 11, 2007 at 08:34
Oops forgot to answer all your question.
Front and rear bearings on a troopy are the same.
Don't worry about trunion bearings as if these go there are likely to be a lot more parts that you will require plus your vehicle is only 3 year old and shouldn't have a problem.
CBC will have the numbers on file so no need to pull apart to get the numbers off the bearings.
Have a great year on the road
AnswerID: 266053
Reply By: Robnicko - Thursday, Oct 11, 2007 at 08:42
Lyndon,
Get prices from different Toyota shops if possible. When I had to replace the UNI's in my 80 series I rang 3 different dealers and got 3 different prices ranging from $48 to $73.50 for rear tailshaft and $55 to $95 for front shaft.
In the end I paid a couple of dollars more for genuine parts as opposed to aftermarket.
I once tried an aftermarket fuel filter (repco) but had to drill out the holes where it mounts to the side of the engine as the original bolt holes were too small.
Rob
AnswerID: 266054
Reply By: Andrew from Vivid Adventures - Thursday, Oct 11, 2007 at 09:25
Ask for a trade discount. Usually you get 10-20% at Tojo dealers.
AnswerID: 266058
Reply By: Member - Phil G (SA) - Thursday, Oct 11, 2007 at 10:31
Lyndon,
Buy a front wheel bearing kit from Adelaide Truck and 4wd Spares on Regency Road.
It will cost you under $40 including seal, gasket and tab washer.
The bearings are Timken (same brand as mine had from the factory). The same bearings are used front and rear - they are also the same bearings all LandCruisers have had since the dawn of time. The rear seals have an extra shroud, but, if needed, you can use a front seal on a rear hub, so theres no issue there.
Maintain your bearings well, and you should never need to use it!
AnswerID: 266071
Follow Up By: Topcat (WA) - Thursday, Oct 11, 2007 at 11:26
I agree with Lyndon. You can get the genuine bearings from dealers in bearings a lot cheaper then going to a Toyota dealer. Just with other Toyota parts. You can shop around & get the genuine part (e.g. lamp reflector lense covers) for as much as 50% cheaper. Cheers.
FollowupID: 528136
Follow Up By: Topcat (WA) - Thursday, Oct 11, 2007 at 11:30
I meant I agree with Phil. Cheers
FollowupID: 528137
Reply By: Member - Shane D (QLD) - Thursday, Oct 11, 2007 at 20:17
Hi Lyndon k,
I got my wheel bearings from terian tamier (don kyatt group) for my 105 cruiser.
Didn't compare price, can't accurately remember how much I payed, however this may be a good alternate source if need be, also heaps of other common spares
Shane.Terrian tamer
here is web site,I'm not affiliated blah blah blah
AnswerID: 266193
