HF Auto Tune Mount
Submitted: Monday, Oct 22, 2007 at 21:16
ThreadID: 50791 Views:2782 Replies:5 FollowUps:2
Hi , Can Anyone Tell Me If There Is a Auto Tune Aerial Mount You Can Buy For Alloy 100 Series Toyota Bullbar?
Reply By: Andrew from Vivid Adventures - Monday, Oct 22, 2007 at 21:22
probably not... in most states it is illegal to place it on the bullbar, although clearly that doesn't stop a lot of folks.
AnswerID: 267876
Reply By: Footloose - Monday, Oct 22, 2007 at 21:38
A fabrication shop should be able to fix it.
However, not only is it illegal in many states, but SWMBO will hit the roof when she sees it in front of her all the time. Wheel placement on the passengers side may also be affected.
Rear mounted A/T's work well, and do not restrict vision.
There are a number of mounts around for the rear of a 100 series.
AnswerID: 267883
Follow Up By: Stu050 - Monday, Oct 22, 2007 at 22:19
Footy,
Up here, one hardly ever sees a rear mount HF aerial, bullbar mounts are the most common.
FollowupID: 530283
Reply By: Stu050 - Monday, Oct 22, 2007 at 22:07
As Footy says, a welding works should be able to weld the required tab(s) onto your alloy bullbar.
Make sure that you tell them it is for a HF autotune antenna, and the rough weight of it. Otherwise they may not make it strong enough.
AnswerID: 267886
Reply By: Member - Doug T (Qld) - Monday, Oct 22, 2007 at 22:45
Try the ARB antenna mount very strong and reliable, No welding required
TJM mount is not suitable, not strong enough and even with a CB antenna on them they flex and crack off
AnswerID: 267890
Follow Up By: Member - Doug T (Qld) - Tuesday, Oct 23, 2007 at 06:14
Been giving the mount some thought, Could be best to get one welded on because I would presume the Auto tuner weighs a bit , but as you have a nice clean bar you don't need to ruin it so I would agree with all the suggestions for the rear mount on the tyre carrier idea m although I have seen them mounted down low on a bullbar on the flat section , only needs a hole drilled for that method, but would not be ideal for some of the modern bars that lean back to much .
FollowupID: 530308
Reply By: Mogul - Monday, Oct 22, 2007 at 23:23
Bullbars are a great place to mount aerials until you have an accident and guess what, no aerial, no radio.
Best to mount it at the rear.
AnswerID: 267894
